HCL5515W Convergence Hello and Help! You posted in March for someone that you can send a link to where I can buy IC's for the convergence module on these Samsung TV's. Also, if you have a link to a maual then I'm going to try to repair this TV. I can be a huge hero to my girlfriend's son if I could fix the big screen. Help me to be superman! Keith
  • KeithGP Apr 29, 2008
    Is there any difference between the Samsung HCL5515W and the HCL5515WX???
    Thanks a million for the information!
    Keith
  • 8,617 Answers
Kieth Yes the link I am posting has both the convergence ICs and the service manual that you need. They will email the service manual out right after purchase. so you can review it while you wait for the ICs they also provide free installation instructions and free online tech support while you do the repair. Your model is contained in the service manual for model HCL6515 it covers about 6 model 1 of which is your model. You will also need (2) STK392-040 Convergence ICs. here is the link, you will like this site they go the extra distance to help people.
http://servicemanuals.vstore.ca/
Posted on Apr 29, 2008
  • Sonny Berry
    Sonny Berry Apr 29, 2008
    No they are the same chassis
My samsung rear projection tv has a problem with its convergence ic. i think theres two ics , but how do i tell which ic need replacing??
Always replace both once your going to the trouble each IC is usually less than $30.
This link will help show you what's involved.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 13, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Bow at top and bottom of screen
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Hope this may help;
Regards,
VOTIT
Aug 04, 2008 | Samsung HCN653W 65" Rear Projection...
Samsung HCM653W Convergence problem
CK low ohm resistors and pico fuses some are green,some are yellow .they will be around ics some may be under heat sinks that hold STKs.
Nov 29, 2008 | Samsung HCM653W 65" Rear Projection...
TW65H80 Convergence IC
The convergence IC is an STK392-110. This is a large black IC attached to a heatsink. First try resoldering the pins on the IC. If that fails to resolve yuor problem. replace the IC. Be sure to use plenty of heatsink compound on the back of the new IC.
Keep us posted.
Dan
Jun 30, 2008 | Toshiba TW65H80 TV
Convergence problem
The Stk392-120 are better ICs if you would like a link to get new ics that provide free instalation instructions with pics let me know and I will post the link.
May 15, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Red Halo Hitachi 53FDX20B (2002) model year
You can get the replacement Convergence ICs at this website I am posting. Just order the same STK numbers that are on your Convergence ICs. They provide instalation instructions and free on line tech support with every purchase. Heres the link.
Apr 11, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Samsung hc-p4752w
Sounds like convergence amp ic's
i dont have any part number for that model.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 14, 2008 | Samsung HC-P4752W 47" Rear Projection...
Converges problem for my RCA 52
good luck
Feb 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
HC-P4752W - IC Replacement vs Convergence Module.
The colors weren't lining up correctly on my HC-P4752W which is only about 30 months old. I did a little bit of research and got ahold of the people at http://servicemanuals.vstore.ca/ They recommended replacing the IC's as well as the IC resistors. I purchased the replacement parts from their site and made the repairs myself. I should mention that I didn't have any previous soldering experience. The repair was easy and a complete success. You may find replacement parts elsewhere for slightly cheaper but what you won't find is the prompt and detailed customer service that they provide. They gave me there # and said to call if I had any questions before or during repair. I took advantage of their services and got answers every time I called.
Aug 11, 2007 | Samsung HC-P4752W 47" Rear Projection...
Picture issues, not sure what the problem is, photos posted
It looks to me like the green is sagging down at the top, and this means that one of your convergence IC's has stopped working. Instead of replacing the whole module, locate the convergence IC (Samsung typically uses the STK392-040 IC's) that handles Green Vertical (GV) and replace it. Sometimes there is a fuse next to the IC that looks like a small resistor that opens up too. If you do not have experience changing convergence than have a qualified tech handle it for you.
Jul 03, 2007 | Samsung HCM4215W 42" Rear Projection...
Televison & Video Logo
160 people viewed this question
Top Televison & Video Experts
