Question about Dell Dimension 4600 PC Desktop
I need help
Everytime my desktop goes to sleep mode and u turn it back on from sleep mode if will go to a blue screen. the error code says physical memory dump 0xc000009c. this is my xps 410 desktop.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    sounds like your computer needs a tuneup..
    Scholar:
  • 186 Answers
If warranty - call it in. Otherwise it sounds like a classic case of bad ram. Find a friend with similar ram in his/her desktop and do a test swap to see if symptoms repeat if you want. Then replace the ram with new. It happens for no reason, or at least nothing you did caused it. Basically it's a page in or out error with the ram causing windows to "freak out" and pop up an error.
You can get a good selection of ram from tigerdirect.com or newegg.com.
Posted on Apr 28, 2008
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
My monitor seems to be stuck in sleep mode
This happens when there is no communication with video card. Check cables, re-seat video card, make sure monitor is set to correct mode. VGA (15pin blue), DVI (white), or HDMI.
Aug 28, 2012 | Dell desktop and monitor- Inspiron 530...
Hit start Alienware computer goest to alien head on screen then straight to sleep mode. Please read
When you say computer clock do you mean the LED read out on the mother board? if so the numbers you are seeing are error codes you will need the mother board manual to know what those codes mean. If you don't have the manual it's possible you can go to the mother board manufacturers web site and download one then you can look up the codes to see what the problems are. Hope this helps
Jul 26, 2012 | Alienware PC Systems Computers & Internet
My LCD Computer monitor keeps going into sleep mode everytime I turn on my computer, Is ther some way to get it out of sleep mode ? Re: 25" LCD Color Display Model # TSS-25m9 Serial # TS25093943
when pc starts hit alt and f4 then select an option from drop down menu by cliking on little v sign on right of box the option that should be there is sleep select shutdown then reboot it might work if not try same steps in safety mode by pressing f8 on first screen when pc starts select safety mode then try those steps again might help
Sep 23, 2010 | Computers & Internet
Why does my screen goes to sleep everytime I start my computer
Go into power options and turn off the fuctions for when the hard drive turnes off and when the monitor turns off, that should keep the computer from going to sleep.
Apr 21, 2010 | Dell Dimension 4600 PC Desktop
My problem is the same, it happens when i'm in fullscreen.
go in and fix the power settings under screen saver disable sleep mode on drives and monitor disable sleep mode on every thing just use blank screen instead
bes fix 4 ya
Jul 29, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Computer will not boot up. I have tried to boot up in safe mode, normal, safe mode with prompt command...nothing works, just goes back to the normal start up screen and keeps doing the normal start up over...
It looks like you're encountering an endless reboot? Here's what to do to find the actual error message.
  1. Turn on the computer, and press F8 after the POST screen but before Windows attempts to start to access the advanced startup options.
  2. Select "Disable Automatic Restart On System Failure" and press Enter.
You should now get a blue screen with an error message and error codes. Please write these codes down and report back.
Mar 24, 2009 | HP Compaq Presario SR1830NX PC Desktop
Sleep Mode Lockup on Dell Inspirion 530 w/ Vista
Try hitting the "Windows" key on your keyboard to bring it out of sleep mode. The "Windows" key is generally found on the bottom row of the keyboard, near the Alt and Ctrl keys, and it has no letters on it, just the Windows logo. That key brings my Windows Vista machines out of sleep mode when other keys won't.
As for the power button, anytime you need to force a computer to turn off, you can press and hold the power button to do so. Usually, you need to hold the power button for 5-10 seconds and it will shut down. Use this option with caution, as it turns the computer off without running through the shutdown process and can cause you to lose data.
Hope this helps.
Mar 08, 2009 | HP Media Center m7060n PC Desktop
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Pc will not go to "sleep" Blue Screen
try reinstall whole system but don`t forgot do back up first ;)
Aug 13, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
150 people viewed this question
Alun Cox
