Question about Dell Axim X5 Pocket PC
Dell Axim problem
There is a horizontal line across the screen 1 - 2 pixel wide. WIth pressure, it move somewhat, but did not want to press too hard. Other things seem to work fine - it is just distracting.
Thanks.
mary.buckman@oregonstate.edu
  • 35 Answers
Most likely a bad connection along the sides of the screen causing a line of "dead" pixels. I have a similar problem with an old GPS reciever (several lines). You could attempt to repair but that would be risky unless you purchased a new working screen and replaed the entire screen (can find on ebay at times)
Posted on Aug 05, 2008
Samsung 53" LED TV ....4 yrs. old. ....has thin horizontal lines (1 pixel wide) across entire screen
are the lines going left to right or up or down? if up or down probaly a bad panel,iff left or right either the upper or lower buffer board is bad
Nov 28, 2014 | Samsung Televison & Video
What can I do to stop by iMac G5 LCD screen from being pixelated and getting dark blue and pink horizontal lines across it?
This very likely a failure in the LCD screen. If you are seeing thin or wide bands, vertical or horizontal across the screen, then you will need to have the unit serviced to repair or replace the screen. If the unit has been dropped or struck (hard) it is possible the connector cable for the screen has come loose, but this is not usually the issue. If the unit is still under warranty, get it serviced. If it is not under warranty, there are several good web sites that provide Do-It-Your-Self instructional videos as well as parts, both new and refurbished and used. If you google your specific model and "screen replacement", you will see a number of results appear that would be of use.
Apr 19, 2013 | Apple iMac G5 Desktop
Dead pixel line?
Hi, The problem with pocket PC is that you can't do something to test and find if the problem comes from the display or the graphic processor. If the device is not too old, you can try to repair it. In case that the device is more than 10 years, buy a new one. Sorry.
May 30, 2017 | Dell Axim X30 Pocket PC
My dell laptop has horizontal lines across the screen
Last one I had with this it was the connection from the compute base to the monitor. difficult to chk and hard to fix yr self. hv it tested. cheers
Aug 04, 2012 | Dell Latitude D520 Notebook
I have a thin horizontal line across my dell latitude laptop screen
If the thin line is always there, you have a set of pixels burned out. This usually occures vertically. There is easy fix, except to replace the screen. If the laptop is under warrenty, contact the manufacture for repair options.
Sorry could not be something easier for you.
Mar 19, 2012 | Dell Latitude D630 Notebook
Can I see the difference
Visually, there is very little difference to the eye of the average consumer between 720p and 1080. However, 720p can deliver a slightly smoother-looking image, due to the fact that lines and pixels are displayed in a consecutive pattern, rather than in an alternate pattern.your tv is display format is 720p and blu ray is 1080p. what happen is it will be scaled into 720p. old tv set format is 480p 720p represents 1,280 pixels displayed across the screen horizontally and 720 pixels down the screen vertically. This arrangement yields 720 horizontal lines on the screen, which are, in turn, displayed progressively, or each line displayed following another. 1080p, on the other hand, represents 1,080 horizontal lines displayed sequentially. This means all lines are displayed during the same pass. 1080p is the highest quality HD display format. 480p represents 720 pixels displayed across the screen horizontally and 480 pixels down the screen vertically. This arrangement yields 480 horizontal lines on the screen, which are, in turn, displayed progressively, or each line displayed following another.
Apr 05, 2009 | Samsung Televison & Video
Screen problem
The pixel sensors at the edge of the screen have gone out causing the line. This is generally due to a bad or failing screen. Unfortunately, the screen will have to be replaced in order to fix this.
Jul 25, 2008 | HP Pavilion dv1000 Notebook
Insignia 32" Tube TV NS-RTV32
The vertical output IC LA7847 is failing. It will likely fail permanately and you will have just the horizontal line. The set will require service. Just do not run the set very long in this state. That thin white line can likely burn into the crt phospher and will show all the time thus ruining the glass picture tube...
Jun 05, 2008 | Televison & Video
Dell Axim X5 Pocket PC Logo
128 people viewed this question
Alun Cox
