Desc rambelingc my motorola box
Is it possible to turn a motorola digital cabel box back on manualy by opening it up and messing with the componets
  • 78 Answers
Not to sound like a smart alec, but if you have to ask this question, then the answer is no. ask your cable provider how to reset it if unplugging it for ten or fifteen seconds does not work. also make sure it is not getting too hot as equipment like this needs to have adequate ventilation. if it is too hot to touch the warmest part of the case, it needs cool air circulating around it, a small fan might keep it from overheating. if it is a "fixed" cable box you're kind of screwed, unless the person you got it from is willing to help.
Posted on Apr 29, 2008
CAN HDMI BE REPLACED?
Yes an HDMI port can be replaced, but more likely you will need to replace the entire board the HDMI resides on. Ports are typically just conductors, ie wires. It's probably not the conductors that are messed up, it's more likely the circuitry that decode the HDMI signal that is messed up. Check your cables and whatever you're trying to connect on another TV with HDMI (perhaps a friends if you don't have another TV with an HDMI port) and make sure your cables and cable box are both operational.
May 03, 2014 | Zenith B50M88W 50" Rear Projection...
Display error no audio also
The problem may be your cable box. If your box is a Motorola , swap it with another possibly from another room in your house. I have run numerous service calls in Dallas / Ft. Worth area only to find the cable box by {MOTOROLA} WAS DEFECTIVE.. Your cable company should also exchange it for free. If the tv does turn out to be the problem, suspect the 24v or 12v from power supply to be low. Probable cause defective capacitors or regulator ic's, or associated zener diodes or open resistors. GOOD LUCK AND LET ME KNOW HOW IT TURNS OUT.....EXPERT-TECH@LIVE.COM
Mar 17, 2014 | Hitachi 42PMA400 42 in. Plasma Television
I am get Free software motorola L6 for java loder via usb data cabel
i lost my motorola L6i software cd.
i want the softwere for PC connectivity
Jun 03, 2009 | Motorola Mobility L6 Cellular Phone
I AM TRYING TO SONGS MANUALY TO MY IPOD
Do this: First plug your ipod into your computer and open itunes. Then go to the ipod's home screen and you should see 4 boxes and a description near each. Click the box next to the description that says manually manage files and a check should appear in the box. It should ask you if you are sure you want to and click yes.
Mar 08, 2009 | Apple iPod nano 3rd Generation
Best way to hook up all my componets
The best way to use the Denon and get your money's worth is to connect all devices to the Denon using HDMI connects if possible, if you use HDMI make sure you assign the audio if needed.
HDMI from Denon to TV. the Denon will upconvert all signals to HDMI to the TV
Jan 29, 2009 | Denon AVR588 Receiver
Motorola w270
Download the drivers from Motorola website.
http://www.motorola.com/support/W270
Jan 20, 2009 | Motorola Mobility W220 Cellular Phone
Code for toshiba remote#ct90251 towork motorola hdtv cable box
When you program the unit, have the TV off, it is probably interfering. If possible, have the front of the cable box behind the TV. I was also told by the cable company to take the lens out of a cheap pair of sunglasses and tape it over the reciever on the cable box. This will block the interference from the TV. Haven't tried it. I have a Toshiba LCD and having it off while programming the reomote to the Motorla cabel box worked.
Sep 11, 2008 | Televison & Video
Ilo 42" plasma tv
Go the the settings on the cable box. look for output resolution, then change it to 1080i and 720p. now turn the box off and back on your tv will now display the input of wither 1080i or 720p depending on the hd channel your watching.
Dec 26, 2007 | Televison & Video
My Xbox doesn't start
When the power adapter is plugged in does the light turn on?
Aug 25, 2007 | Microsoft Xbox 360 Console
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
