Question about Zenith Z25X22S 25" TV
Zenith tv, video retrace lines.
This is a 90's 25 inches tv set model Z25X22S (GX generic chasis) it came with horizontal retrace lines as if G2 screen control would be too high, I checked and it was normal, I changhed the video B+ capacitor and it make no effect, then I checked all video and smps B+ waveforms and all seems to be normal, I really don't know what I'm missing, I know that this is an old tv set but maybe someone of you expirienced guys had have the same problem and know this case, any posible help is really apreciated, thanks.
  • 71 Answers
How is the 200 volt supply to the video output transistors??
measure the collector voltage of the video output transistors with the crt board on and off the crt. if voltage goes up when crt board is off then crt shorted
Posted on Apr 30, 2008
How do you fix horizontal lines on a zenith tv
Retrace lines. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site with keyword 'retrace lines'
Mar 23, 2015 | Zenith Televison & Video
My Zenith SG2721H has thin green horizontal lines across the screen.
Most "modern" CRT TVs have automatic color biasing which means a complete of manual control. Depending on how your set is manufactured, it may have a control for each color located on the neck board for adjusting the drive to each of the CRT guns.
What you're seeing is called 'retrace' and you're correct that this has to do with color blanking. The most common issue causing 'faint' retrace is too much drive to one of the CRT guns. Hopefully, your set has an adjustment to back off the drive for the green gun. If not, this can be the result of a bad capacitor or leaky transistor in the green circuit.
If all else fails, locate the SCREEN of G2 knob on the back of the flyback transformer and back it down a touch; sometimes this is all it takes.
Dec 14, 2012 | Televison & Video
Where is the vertical adjustment knob on the Zenith Z25X22S and how do I get to it?
many new TV's having vertical hold most of the case you need service mode to change the setting
Aug 24, 2010 | Zenith Z25X22S 25" TV
How do we set the g2 voltage properly
turn blue black to off. turn tv to av mode. then adjust g2..until retrace lines appear on the screen.then decrease the g2 until the retrace lines disappear.
Apr 07, 2010 | Orion STV2763 27" TV
DVD viewing shows in black and white
you have to change color system of dvd(ntsc, pal,) normally dvd remote will p/n button..press it to change color system,,otherwise u have to change color system of ur tv
Mar 15, 2010 | Zenith Z25X22S 25" TV
Sony KP65WS500 5 blinks
1st set Brightness and Contrast settings to 50% at tv menu.
You need to cover 2 CRTs with any thing like thick paper while adjusting 3rd CRT.
For example, lets adjust Red CRT G2 volts, Select audio-video input 1 and cover green and blue lens with paper note-book and rotate Screen control up to level where you see retrace lines on projection screen, now decrease screen volts (G2) so retrace lines disappear and projection screen should be blank.
Now do same process with green and blue adjustment while other lenses should be covered.
Im not sure I conveyed it to you properly or not because English is not my 1st language.
Thank you.
Sep 23, 2008 | Televison & Video
No Picture
This is a problem with the vertical circuit. If you can solder, you should be able to fix this. With teh unit unplugged, open up the back and locate the vetical IC. This should be a small flat IC attached to a heatsink with about 9-11 pins. It may be marked LA7837 or something similar. Try resoldering hte pins. If that fails to resolve the problem, replace the IC. I will look up your specific model and try to get more details.
Dan
Sep 16, 2008 | Zenith Z25X22S 25" TV
Zenith Z25X22S 25" TV can't read scores at top or bottom
On the inside of the TV, there will be a knob with a RED cap on it, labeled vertial position. (it actually looks like a variable inductor)
With an allen wrench (possible 1/4) give it a half turn in either direction and see what happens. On the Z25x22S model, the vertical and horizontal position adjustments should be right next to eachother, but on the model i worked on, there was no variable pot for the horizontal position.
Hope this helps!
Jan 27, 2008 | Zenith Z25X22S 25" TV
Very poor picture
  • your problem is called picture with retrace lines.
  •  your problem is in video output circuit
  • as you are saying that it was off for a year that means there is possibility of loose contact in that section.
  • plz check the following
  • supply to video output absent or loose print.
  • loose connector in crt base.
  • crt base loose
  • voltage on screen control or g2 absent or wire loose.
  • screen control located on flyback transformer mistuned.
  • hope this will help
  • good luck.
Oct 19, 2007 | Proscan PS32125 32" TV
Service Manual, or sugestions
https://www.manualsparadise.com/ShowProductsForModel.do?model=M25715316 they have service manual and schematics - sorry had no luck with a free one but the prices aren't too bad. Hope this helps :)
Mar 13, 2007 | Zenith A25A11D 25" TV
Televison & Video Logo
129 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
