MY AIWA CX-NA50 SIMPLY QUIT, IN SPITE OF POWER GOING TO THE UNIT AND TESTED BY PLUGGING INTO ANOTHER WORKING POWER OUTLET.
  • 6 more comments
  • dlemke2235 Apr 29, 2008
    NOTHING ON THE FRONT PANEL. I HAVEN'T FOUND THE LOCATION OF ANY FUSE ANYWHERE ON THE UNIT. ENLIGHTEN?
    THERE IS NO CABLE. ARE YOU REFERRING TO THE POWER CORD?
    THE UNIT WAS WORKING JUST FINE, WHEN IT QUIT AS IF THE POWER CORD WAS UNPLUGGED.
    I DONT HAVE A SPARE POWER CORD. BESIDES, THE UNIT HAS TO BE OPENED UP FOR THAT, AND THAT IS A SERVICE MAN'S JOB. WHEN PLUGGED IN TO A LIVE OUTLET, THERE IS A CLICK INSIDE THE UNIT, BUT IT STILL DOES NOT POWER ON.
    I SAW THAT IN MY MANUAL, BUT THAT PROCEDURE ONLY RESETS THE MEMORY, AND POWER IS NEEDED TO DO THAT. I TRIED IT AFTER PLUGGING INTO AN OUTLET, BUT NOTHING IS ON.
    THERE IS NO FUSE SOCKET ON THE OUTSIDE OF THE CASE. IF THERE IS ONE INSIDE THE CASE, THAT AGAIN WOULD BE FOR A SERVICE MAN TO DISCOVER.
    THE POWER RESET DID NOT WORK BECAUSE OF THE LACK OF POWER.
  • Anonymous Mar 26, 2014
    Where to get belts
    Genius:
  • 1,447 Answers
Chances are there bad connectors on the unit itself, have you tried a different cable? try a different cable as well.
Hope that helps
Posted on Apr 29, 2008
  • 1 more comment
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 29, 2008
    Yep change the power cords.
    Does it have a fuse? have you tried checking/replacing it?
    Power supply might be damaged in that case, or wirings might gone bad, no other Troubleshooting that we can try honestly. Call customer service for a certified servicer.
  • 758 Answers
Could you provide more info about your problems?
  • Jean Sintulaire Apr 29, 2008
    When you say quit..do you mean thats it doenst power on?
    Genius:
  • 3,587 Answers
Nothing on the front panel indicators? did you check the fuse?
  • 2 more comments
  • Patrick Michaels
    Patrick Michaels Apr 29, 2008
    apparently, you can press power and clear at same time to reset the machine..I will post the user manual under the model name at fixya
  • Patrick Michaels
    behind this link, on pdf, there is a troubleshooting page towards the back with some information on resetting the power memory.
  • Patrick Michaels
    did you try the power reset as mentioned in the users manual, yet?
  • Patrick Michaels
    well..then..it's time for a service man..you need some help finding one in your area?
The AIWA CX-ZR525 wont play cd's, it will only pick them up and leave them there with no music
Presuming that other sources work okay and the the cables are connected correctly.....Try a CD Lens cleaner.
If that doesn't work then it's time to open up the unit and manually clean the laser lens. If that still doesn't work then the laser might be dead. Replacement parts may be available. Whether or not you can do this as a DIY repair though is questionable. It depends on your skill.
Sep 14, 2014 | Audio Players & Recorders
Aiwa mod. CX-ZR774 System will not power up
I assume that the Aiwa controls the other components, such as a CD changer. If these units are plugged into the rear of the Aiwa, then they may not be receiving power due to an auxiliary switch being off, or a bus breaker being blown. Breakers are on the back panel of the unit. They have a black thumbscrew that turns out counterclockwise. Take the fuse to Radio Shack to confirm if it is good or not, and good a new one if not. If the components are not connected to the Aiwa, then I have the ask the stupid question of are they plugged in, or is the surge protector that they are plugged into plugged in. Remember that even modern surge protectors have breaker switches, and may need resetting, especially after a snow or thunderstorm. Good luck.
Jan 27, 2014 | Aiwa Audio Players & Recorders
I can't get my clock set on my aiwa cx-nma545 & I no longer have a remote.
The original remote is needed to get into the main menu, try www.aiwa.com contact customer support, also! go to www.ebay.com type make and model of unit and go through the list you might get lucky.
Jun 24, 2012 | Audio Players & Recorders
Aiwa 3CD changer,Model no.CX-NK550HR, CD Player not working.CD Board is required to be renewed.Where can I get original CD board of above mentioned model
some one help me...my aiwa vcd component model no. CX-NK550HR suddenly dont open or power up... i think it have a problem in its transformer...what do u think???kindly send me a response on my problem pls.....
ym:jhongojar
email add; near.evil@yahoo.com
Nov 12, 2009 | Aiwa Audio Players & Recorders
Aiwa cd3 model #cx-na 22u will not acknowledge cds spins then stops
Optical lens might have dust on it so...Try to clean optical lens with cleaner CD then check.
If problem still exist then clean lens with cotton bud by taking off top cover of unit. Make sure to unplug unit from AC outlet before opening top cover.
Jan 09, 2009 | Audio Players & Recorders
Aiwa Stereo
Same model, same problem. (CX NA-50) I have one that worked great for two years (at best) and I haven't used it since then. I recently decided to look for a solution via the internet.
I read somewhere else that there was a class action settlement with aiwa (now expired) since many of these units had this problem.
Oct 25, 2008 | Aiwa NSX-DS55 CD Shelf System
HOME STEREO SYSTEM CD PLAYER
I WOULD LIKE TO KNOW WHY AFTER PAYING WHAT I DID FOR YOUR ENTERTAINMENT CENTER THAT I WOULD HAVE TO PAY FOR THE REPAIR SERVICE PLAN?????? THAT JUST DOESN'T SEEM FAIR AT ALL TO THE CONSUMER. I WOULD LIKE THE EMAIL ADDRESS TO SOMEONE OF SUPVISOR POSITION. THANK YOU
INSTEAD OF CLOSING THE CD LOADER WITH THE OPEN/CLOSE BUTTON SIMPLY CLOSED IT BY CHOOSING THE TRACT NUMBER WANTING TO PLAY. SO FAR IT HAS WORKED. BUT WILL NOT WORK AUTOMATICALLY WILL TRY PROGM. THE REMOTE NEXT SEE IF THERE IS ANY LUCK WITH THAT PART.
THANK YOU
Jul 06, 2008 | Aiwa NSX-A115 Shelf System
My Remote Control Unit for my Aiwa Digital Audio System CX-NA707
It would be a lot quicker (and could be cheaper) to spring for a universal remote.
Mar 17, 2008 | Aiwa NSX-AVH80 System
No Power
How do you knoe it's good? Does it LOOK good, or did you test it with an ohmmeter? Sometimes - particularly when the get old a fuse can LOOK good, but be bad.
Other possibilities - power cord, plug or outlet bad (is the outlet the un it's plugged into on a switch? Are there other WORKING appliances plugged into the same outlet?)
Sometimes there are other fuses not readily visable - INSIDE the unit.
Last - and worst power supply in the unit simply quit. And that a big repair.
Let me know what you find.
Mar 01, 2008 | Teac R-H300 Dual Cassette Deck
234 people viewed this question
 Grubhead
Grubhead
