Question about Video Game Consoles & Games
Ip address wont work - Video Game Consoles & Games
    Problem Solver:
  • 8 Answers
I has to work, make sure that he security key its right. because one of the major problems of not been able to obtain IP address is because the WEP/WPA key or what ever type of security key you use is type incorrect. try re-typing your security key again and that should solve the problem.
Posted on May 01, 2008
Change ip address
If your IP address is static,you cannot change it.Static IP will not change even when you reset the modem.You have to contact your Internet Service provider(ISP) for changing static IP.If your IP address is dynamic,it will change whenever you reset the modem.If you want to check your IP address,visit Ip-details.com .
May 11, 2013 | Toshiba Satellite Computers & Internet
Why will it not connect to the internets IP address?
If you reset the modem and ip address will not change and remains same hence it is static ip address.If you reset the modem and the ip address change ,it is dynamic ip address.
You can get the Ip address from your internet service provider.you can check the ip address using the site Ip-details.com .
Jan 25, 2013 | RCA DCW615R Wireless/Cable Modem
4300 laserjet wont print docs. IP address is same as a network computer, cannot change IP address? Configuration page prints and I check ports etc but will not print. cannot change IP address. Help....
Have you tried changing the IP address from within the driver's properties? Go into the print driver properties, and under the Ports tab, edit the 4300's port and change the IP address that it is associated with. You may need to reboot the printer once you make the change and save it, but that should allow you to change its IP address.
Jun 13, 2011 | HP LaserJet 4300 Printer
My laptop is wont connect to the internet?
check your cable if it is connect to a modem or DSL/ADSL router then it must be straight cable;for more information regarding the cabling go to http://www.makeitsimple.com/how-to/dyi_crossover.htm;usually ip address and DNS address is assigned automatically by the modem or DSL router.so set your network connection to obtained ip address and DNS address automatically untill and an unless you are given the ip address and DNS address to be configured manually. check your ethernet card is working by pinging to 127.0.0.1;hope it sloves your problem
Nov 17, 2009 | Computers & Internet
IP Address problem
how do you know what the ip address is? you need to log into your router and find the device that says nfusion and that will be the ip try going there.
it wont just be YOUR ip address
Aug 03, 2009 | Televison & Video
Xbox 360
  1. First, turn your Router off and wait for a couple of minutes (unplug power from the wall)
  2. Turn off your modem (unplug power from the wall)
Reboot both the devices and they will obtain a new IP address.
Let me know.
Jul 09, 2009 | Microsoft Wireless Network Adapter Xbox...
I am trying to connect to the wireless in my new apartment. I have entered my network and password and that has worked fine. However, under Wireless Network Connection Status (i can get there by clicking...
On the Support tab - what does it say the "Address Type" ?
If its DHCP then check that on the TCP/IP properties;
If on "automatic IP address" then it wont take any entered IP address.
Do not put any IP address.
Check that "Obtain an IP address automatically" is checked and also "Obtain DNS server address automatically" is also checked. On wireless network tab check "Use Windows to configure my wireless network settings".
On preferred network check that your wireless network is there, if not add it and move it up
Jan 26, 2009 | Dell Inspiron 2200 Notebook
Xbox live
you can set a static ip address to your xbox if it's not detecting it automatically.
in order for you to know what ip address to set, go to the command prompt (for windows xp: click on start, then run, type cmd). when you're on the command prompt, type ipconfig/all and hit enter. tahe note of the default gateway, subnet mask and dns 1 and 2. for example, the default gateway is 192.168.1.1, you can set your xbox using the ip address 192.168.1.2 and up (note: you just need to make sure that you are going to use an ip address that is not being used by any other devices that are also connected to the router).
hope this'll help you
ciao!
Oct 22, 2008 | Westell Wirespeed VersaLink...
Connecting Brother MFC 7420 thru Dlink DP301P Print Server to home network with ONLY dynamic addressing
I went and got static IP addresses from internet provider...Must of caught them on a good day
Apr 24, 2008 | Brother MFC 7420 All-In-One Laser Printer
WRT54G linksys router
The first thing I would do is check to make sure the desktop with XP has the network card set to "obtain an IP address automatically"
if it is set to obtain an ip address automatically, I need to know the following:
What is the IP addresss of the router?
What is the IP address of the Vista computer?
What is the IP address of the xp computer?
You can find the ip address by going to start, then run, then type cmd and hit enter. at a command prompt type: ipconfig and hit enter.
Feb 21, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
