Question about Vacuums
Vacuflo 260. All of a sudden not working. Something smells like it's burning. As opposed to the motor...could it be a faulty switch (how's that for optomism?)?
    President:
  • 1,673 Answers
If it is an electrical smell, then it is probably the motor, a switch is possible tho. If it is a rubber smell, then it is the belt slipping, replace it, and check the brush roll, the ends should turn easily.
Posted on Apr 29, 2008
Vax v-091 burning smell and clunking noise
Is there something stuck inside, underneath, being turned along with the motor? burning smell usually means something got caught and the belt snapped. Not expensive and don't know if it's an easy DYI. Shouldn't cost too much to have it repaired or you can google the brand and model and the word belt, see what you find.
Mar 01, 2014 | VAX Appliances 2000 Canister Vacuum
Vacuum motor noise and smell
If the ball was stuck and you sucked water into the motor it could cause it to smell like it's burning if it ruined the motor
Jan 10, 2014 | Shop Vac Vacuums
Bissell bagless vacuum just stopped working
the most likely to be overheated the motor, or cut the cord.
for the first unplug the power supply and let it COLD, ALSO CAN SWITCH AUTOMATIC OVERHEATING or proving or proving MANUAL. for the second take the machine to an electrician to check out the cable.
Nov 28, 2013 | Bissell PowerForce Helix Bagless Upright...
Switched on my dyson dc 14, but suddenly started to splutter, smell of burning, i switched it off and now it wont switch back on. i have changed the fuse.
Burning smell is NOT good. Sounds like an electrical short in the motor field windings. You'll have to take the machine apart to locate where the damage occurred and see what can possibly be repaired or needs to be replaced.
Oct 14, 2013 | Vacuums
My rainbow 1650- was working fine then all of a sudden it powered down and had a burning smelt a little electrical, but also like something else. Then I hit power switch andi unplugged The unit. I took...
It might have been the wad passing through but with a burning electrical smell it should be checked out by qualified technician. Burning electrical smell means it may catch on fire
Sep 23, 2013 | Vacuums
My dtx1300 burned out when my son kept vacuuming with the bag full suddenly it stop working and I could smell a light burn.what part would do that so I could may be fix it?
the belt that drives the beater bar may have broken. If you noticed a burned rubber smell it was the belt and you can find the part number in your book that came with your machine.
Aug 16, 2011 | Oreck DutchTech DTX1300C with Motorized...
Vacuum smells like something is burning
Ok...Check the brush roll is free not sticky..Next is the belt okay, not jamming on the brush roll making the burning smell...You could take off the roll and run motor on its own ..finding out if its the motor..
Apr 13, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Vacuums Logo
385 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
