Using a Toshiba D-VR610KU, I dubbed from VCR to DVD after formatting for DVD-RW video mode. I finalized it and it played back on the Toshiba. Then I tried to play it on my Go-Video DVR 5000 and the disc is not recognized. What can I do to get a playable disc on other machines?
  • 1 more comment
  • Anonymous Oct 28, 2008
    I can't dub to a dvd+R machine says it supports it.
    Thoughts?
  • davecat Mar 24, 2009
    I dubbed from VCR to DVD using DVD+R media. I finalized and it
    plays back on the Toshiba and my PC DVD drive; however, it is not recognized by a Zenith XBV243. Is this an issue of not properly finalizing or is this a compatibility problem with this media anf the Zenith?
  • Anonymous Mar 30, 2014
    Doesn't read my DVD-R discs dubbed from my video camera,yet on p38 shows them to be playable???
Most DVD players cannot playback DVD-RW disc. Use a DVD-R or DVD+R disc and format accordingly.
Posted on Jun 04, 2008
DVR620KU From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized
Using a DVD-RW disk, try ALL different recording settings even if they don't seem probable and record a sample. If output is correct with all BUT the HDMI-cable, go through ALL picture format settings on the TV when a HDMI-cable is used. Different discs and HDMI cables don't have anything to do with this. I'm still chewing on this...
Dec 15, 2014 | Toshiba DVR620 DVD Recorder/VCR
How to use without remote
UPC 961613194763 053818570722
  • HDMI Output (rear), Remote control, Plays DVD Video, DVD_R/RW (VR format), DVD-R/RW (Video format), CD-R/RW, Audio CD, MP3)
  • MAGNAVOX ZV427MG9 DVD Recorder / VCR Combo LINE-IN RECORDING (NO TUNER)
  • 1080 Up-Conversion, Progressive Scan Video Out
  • Five Speed for up to 6-Hours Recording, Dolby Digital Stream Out
  • 2-Way Dubbing (VCR > DVD, DVD > VCR), Satellite Link Recording, S-Video Input / Output
  • Dec 02, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
    I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
    Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
    (DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
    The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
    I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
    Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
    You can use any brand of DVD, just take note of the format before recording/playing.
    Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
    Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
    OK here's what the user manual has to say on it!
    PS If you need the user manual I will E-Mail on request.
    Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
    Note for recording to a disc:
    • Make sure that the disc is recordable.
    Hit [SETUP].
    Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
    proceed to step 3.
    Using [
    K / L], select “Advanced Setting Menu”.
    Hit [ENTER].
    Using [
    K / L], select “Recording”. Hit [ENTER].
    Recording menu will appear.
    Using [
    K / L], select “Dubbing Mode”. Hit
    [ENTER].
    Option window will appear.
    Recording
    Auto Chapter 10 minutes
    Timer Programming
    DVD-RW Recording Format Video mode
    Auto Finalize
    Dubbing Mode VCR DVD
    VCR DVD
    Recording
    Timer Programming
    Auto Finalize
    DVD
    VCR
    DVD-RW DVD-R
    VR
    DVD-RW
    Video
    Note
    For VCR to DVD duplication:
    • After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
    5
    Using [
    K / L], select “VCR DVD”. Hit [ENTER].
    6
    Hit [SETUP] to exit.
    Make sure to select a recording speed using [REC SPEED].
    7
    Hit [PLAY
    B].Then hit [PAUSE F] at the point you
    wish to start recording.
    • Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
    when selecting the starting point.
    8
    Hit [DUBBING].
    VCR to DVD duplication will start.
    9
    Hit [STOP
    C] to stop the
    recording.
    When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
    • Dubbing Mode is available only if the videotape or disc is not copy protected.
    • You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
    • The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
    May 12, 2010 | Televison & Video
    I am trying to record from cable tv to dvd and also dub a vcr tape to dvd. i've tried both dvd -r and +r. do i need to format these disks first, also when done do i need to finalize and or make compatible....
    DVD-R and DVD+RW and +R are automatically formatted. DVD-WR can be formatted in VR or Video mode Finalization is necessary for -rw and dvd-r, but only recommended for dvd+rw and dvd+r
    Apr 30, 2010 | Toshiba D-VR600
    VHS to DVD-R dubbs fine: but won't play on SONY DVD player.
    Please finalize burned DVD to play in another dvd player.
    Apr 16, 2009 | Panasonic DMR-E75V DVD Player/VCR
    Can not get dubbing to work
    Samsung's solution to many problems seem to be the type of dvd. Try using a dvd-r. I am able to select dubbing with a dvd+r, but the +r discs won't play in other dvd players. Apparently, -r is the only disc to use with this box to avoid issues. The +r records the soundtrack a few seconds off of the video track.
    Dec 14, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
    Zenith xbr411 DVD recorder
    See the manual, page 8:
    What are “Recording modes”? for DVD-RW
    There are two recording modes available using this
    recorder: VR mode and Video mode. When recording to
    a DVD-R disc, recordings are always in Video mode.
    DVD-RW discs can be formatted for VR mode recording
    or Video mode recording.
    VR mode recording
    • 4 different picture quality/recording time settings available
    (SP, LP, EP, XP)
    • Not playable on regular DVD players
    • Recordings can be extensively edited
    • Total number of titles on the disc should be less than
    99.
    (SP, LP, EP, XP)
    • Playable on regular DVD players (after finalizing)
    • Limited editing features
    99.
    Note :
    DVD-Video Format (Video mode) is a new format for
    recording on DVD-R/RW discs that was approved by
    the DVD Forum in 2000. You may therefore experience
    problems playing recordable DVD discs in some players.
    Symptoms include video artifacts, audio and/or
    video dropouts and playback suddenly stopping.
    Our company cannot take responsibility for problems
    playing discs recorded on this VCR/DVD Recorder in
    other players.
    May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
    Televison & Video Logo
    625 people viewed this question
    Top Televison & Video Experts
