Question about Toshiba 50HP66 50 in. Plasma Television
Problem with tuner
Will not change channels with remote nor buttons on top of unit
  • 1 more comment
  • bvillega Sep 08, 2008
    cahnnel does not change when using the up and down buttons on the TV or the remote also the 0 does not work if it is the first 3 selected i have the 42 in plasma
  • vrsmith Nov 03, 2008
    When i change channels all I get is a message "searching... please wait". The nothing happens and the message disappears. Is this a tuner problem?
  • James Peters
    James Peters May 11, 2010
    What model and manufacture is the TV in question.
Found the solution somewhere else...
Unplug it while it is powered on. Worked for me.
Posted on Nov 03, 2008
I purchased a car with a Kenwood DPX-04. There is no remote. How do I get the Tuner to change from pre set channels?
That's a seriously outdated unit. If you have no remote & none of the buttons on the unit (FF, Rewind, etc) work to change the station, you're screwed. You'll have to either listen to what's there or buy a new unit.
Oct 02, 2016 | Kenwood Car Audio & Video
Why does the channel up or down sometimes not work?
It sounds to me like you have a fault in the tuner circuit. I suggest you take it on for service.
Oct 23, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
How to change channel with out a remote
Turn on unit keep depressed the eject button while the tuner or D5Viv is on the screen it will automatically go down do not have a did when attempting this.. lol...
Jun 12, 2014 | Philips DVDR3505/37 DVD Recorder
Bought it used without a manual. when turned on the channel is set to a channel that we dont receive. cant figure out how to set a new start channel.
You can access the on-screen menu by pressing the Vol+ and Vol- buttons together on the front of the TV . Alternatively use a remote and press Menu to access the menu (not all low end remotes will match the feature) An exact replacement remote is available here: . Then use the channel up and down buttons on the TV to select menu items. If using the remote use the play, fast forward, fast rewind back and pause to go through the menus. Press Menu to go back one level in the menus.
Once you have the menu up, go to the bottom of the list to Install. Select Tuner Mode (the options are Antenna, Cable and Auto) and make sure that is set correctly. Next select Auto Program to look for all available channels or Edit Channels to change the channels you will see when you change the channel with the Channel up and down buttons.
Please note that the TV only has an NTSC (analog) tuner and must be used with a set-top box to see any channels other than the remaining low power stations that have not switched to digital.
Once you have a new channel list, the TV will remember the last state it was in. (Please note that the A/V inputs are reached by pressing Channel up or down past the tuner channels.
For more support information: see .
I hope this helps.
Oct 23, 2010 | Philips Magnavox MS3252S 32" TV
I have a Toshiba TV/VCR/DVD combo, remote WC-FN2. I can turn the TV on,change volume but can not change channels. Help! Thanks,
Some tv remotes will do this if the TV is programmed to skip all but one channel (or the last scan for channels had only one active channel - like a tv connected to a set top box (3,4,60)).
See if you can navigate to other channels by typing in a channel number. Also check if the Tuner is the current source of the video signal by pressing the Source or Input button. If you have a menu button on the TV or the remote, try rescanning channels or editing the channel list.
I hope this helps.
Sep 23, 2010 | Computers & Internet
Sony kv-36fs16
Maybe the other channels was skip. check it Menu setting under Preset menu. check other channel it should be skip OFF.
Jun 07, 2009 | Sony KV-36FS16 36" TV
Run a channel scan on the DTV and/or TV input depending on what one your not getting channels on. This will solve your issue.
Change the input on the unit to the DTV or TV input. Press the menu button on the remote. Navigate to the tuner DTV or TV tuner setup menu. Go down to auto search using the down arrow. go right when with auto search selected. This may take a few minutes but you should have all the channels back after the scan.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Change to channel 3 rather than 2 on Zenith 27" withot a remote
You can use the menu button on the front to autoprogram the unit. Make sure the direct tv is on so the tuner will pick it up. After that, you can program the direct tv remote to operate the tv. The reason the channels won't change is there are none in the memory
Dec 19, 2008 | Zenith C27A24T 27" TV
Either the channel up and down buttons have both broken (unlikely) or everything else is working except the remote is not telling the device you are controlling to change the channel up or down.
Since all the other buttons are working well, that also requires that the receiving end of the pair to be working well, thus ruling out problems on that end.
Solution: Reprogram your remote to support the appropriate channel up/down codes for your TV/Tuner in question.
Dec 14, 2007 | Sony RM-AV2100 LCD Touchscreen Remote...
Ghost in the channel selector
the problems due to the microprocessor on the remote reciever present inside the tv .i think the remote is normal working. as the only problem with your iinfra red reciever microprocessor.microcontroler circuit. Replace the IC to solve this. Check electrolytic capacitor coupled to the memory block of the micro processor. Contact service if you are not well verse doing all this rectification works. it is off high risk and caution
thank you !
Nov 17, 2007 | RCA F36650 36" TV
Toshiba 50HP66 50 in. Plasma Television Logo
50 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
