Question about Minolta Maxxum 300si 35mm SLR Camera
MINOLTA MAXXUM 300si
I RECENTLY PURCHASED THIS CAMERA BUT THE SHUTTER DOESN'T SEEM TO WORK. EVERYTHING ELSE SEEMS TO WORK.
  • MaryJaneTo Sep 04, 2008
    hello i have a minolta maxxum 300si and i lost the manual. this might seem like a dumb question but does this camera have a manual mode to change the F-stops yourself? I cant change it from automatic...
    Problem Solver:
  • 14 Answers
Try www.flcamerarepair.com No chg. for ests.
Posted on Jul 31, 2008
I have tried AA batteries and the cover does not close. AAA seems to have the same problem. I have not been able to locate my user manual. I would so aprreciate any suggestions. Thank you~
The Maxum 300si uses one six-volt 2CR5 battery, which should be available at just about any electronics store. Try a Radio Shack, if they exist in your corner of the world.
You may download a copy of the manual from here.
Nov 09, 2012 | Minolta Maxxum 300si 35mm SLR Camera
Camera keeps rewinding film
Check the manual rewind button on the bottom plate of the camera. Make sure the button is not jammed under the edge of the button opening. If it is you might be able to carefully pry it out with a sharp pin or tooth pick (be careful not to pierce the button or you could damage the circuit board underneath) Or you could remove the bottom plate and reseat the button (be careful of a loose spring to the film door latch)
Dec 03, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Battery problem with a minolta dynax 300si
problems with the Minolta Dynax 300si Battery
Oct 27, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Minolta maxxum 300si (Filters?)
Hey sunnibeach4,
On SLR cameras the filters are attached to the end of the lens via threads inside the end of the lens barrel. Without knowing exactly what lens you are using I can't tell you what filter diameter you need but most lenses list that information on the inside rim of the front of the lens. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 08, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Minolta maxxum 300si 35mm camera battery
It takes either: Energizer 475 or Duracell 245........if camera still will not fire, your camera has a problem. www.flcamerarepair.com
Jun 28, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Film advance
It usually is the shutter not firing therefore jamming the advance. Try www.flcamerarepair.com They do not charge for ests.
If it has a Minlota mount, yes!
Jun 02, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Going through the airport...
Try removing battery and then re-install. If that doen't help, try www.flcamerarepair.com They do not chg for ests
May 17, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Minolta Maxxum 300si 35mm SLR Camera Logo
107 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
