I have a hp laserjet 1200 series, got to work turned it on and it wont print, the lights are staying on solid and not flashing which usally means its ready it wont print at all, I read the manual and it says unplug it for 5 mins then try again I did that but still the same
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    hmmm..ok...you may need to re install the software..got the cd? if not, come back here, and we'll hook you up to the hp support site..
There's a loose connection at printers left side.. the cable found at the lower part...
Posted on Jun 10, 2008
    Genius:
  • 3,587 Answers
And read this, please to help us assist you
click here
Posted on Apr 28, 2008
PC communicates with my HP laserjet 1020 but paper does not seem to pull through and wont print and orange fault light flashes then stays on
nothibg to warry about it just check tonner if its ok then do the servicing and also see for the paper jam chek may be ther e inside paper was jamed yeterday
Jun 07, 2012 | HP LaserJet 1020 Printer
My hp laserjet 1200 series printer will not stop intermittantly printing single pages of a multi page document holtbldr@bellsouth.net
Turn off computer,turn off printer disconnect comm cable for 5 min,reconnect reboot should stop intermitted printing
Jan 18, 2011 | HP LaserJet 1200 Printer
Hp laserjet 1200
If you want the printer driver for your HP printer then -
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
Dec 09, 2010 | Office Equipment & Supplies
My orange light next to the yellow dot blinking and the printer will not print
When the orange light is solid it means the cartridge is low and you can still print. But when the orange light is flashing it means the cartridge is empty and the printer stops printing. To continue printing you will need to replace the yellow toner cartridge. The part numbers are Q3972 regular yield or Q3962A high yield.
Jun 23, 2010 | HP LaserJet 2550n Printer
Green horseshoe light is continually lit
If it is solid on, it means the printer is ready to print; no action is required. If it's flashing, it means the printer is processing data and should print soon.
If you are printing from your computer and nothing comes out, with the "Horseshoe" light staying solid, I suggest checking the connection between your computer and the printer, or at least the printer configuration. Most of the time, unplugging, then plugging cables back in does the trick.
Jul 06, 2009 | HP Color LaserJet 2550n printer + HP Color...
Imaging drum LED stays on continuously
When the Imaging Drum LED stays solid on, it means your imaging drum is running low and will soon need to be replaced. You can unseat, then reseat it and see if that solves the problem.
If everything is printing fine, don't do anything until the LED starts flashing. HP will tell you to replace the drum immediately, but mine was on for a year, with moderate printing, before going to the flashing, "empty" state. This is the same advice as for toner cartridges, which are sometimes as much as 50% full when the light comes on.
However, I suggest sourcing a new drum so you can be prepared for when the existing one goes out. Also, despite HP's warnings of gloom and doom, aftermarket products work acceptably.
Apr 22, 2009 | HP Color LaserJet 2550n printer + HP Color...
HP LaserJet 1200 series
Hi vgde2004: Here are some things to check.
1. The printer is in manual feed mode.
Possible solution: Change the manual feed setting in "printer properties"
2. The door is open,the media is out,the toner cartridge is installed incorrectly,or the paper is jammed. Check paper path.
3.Fan error
Solution:
1. Check fan cables for looseness.
2. Replace fan assembly
Dec 15, 2008 | HP Color LaserJet 3500 Printer
In the middle of printing a document my laserjet 5L just screamed
Is the light flashing or on solid? They have different meanings
Nov 16, 2008 | HP LaserJet 5L Printer
Hp laserjet 1200 series
Remove the DIMM and reseat it.
If the printer still has an error, replace the DIMM.
Unplug the power, reseat the paper tray, and reattach the power cable.
Oct 20, 2008 | HP LaserJet 1200 Printer
Hp lj 1200
How much Price HP lj 1200 at Sisney- Astralia?
Aug 16, 2008 | HP LaserJet 1200 Printer
81 people viewed this question
jasbo
jasbo
