Question about Char-Broil Electric H2O Smoker
Tripping the electrical Breaker
My four year old Char-Broil electric H2O smoker is tripping the electrical breaker after a short period of operation. What is the fix?
  • Anonymous May 10, 2008
  • smoker2 May 26, 2008
    I have the same problem. I moved the smoker to a different outlet, nothing else on the circuit and plugged it directly in (no extension cord). Still tripped the GFCI. ??
I have used the charbroil bullet electric H2O smokers for years (wore 2 out - currently on my 3rd). I won't use anything else (having used many, many others - HOWEVER - as with every product made there are things to watch or overcome. Learn to use it properly and look forward to many years of great BBQ.
Ambient (outside) air temp below 70 (depending on wind also) will affect these smokers drastically - highly recomend getting or making a "smoker blanket" (got mine at cabelas years back - if you can't find one welding blankets from an industrial supply store can be made into one) to insulate the sides - this drastically reduces heat loss and reduces the electrical load.
Another MAJOR mistake many people make is extension cords - avoid the use of them at all if possible - if not possible then purchase the heaviest gauge you can find.
Always pre-heat your smoker - Always use boiling water (or other liquid) in the H2O pan added after smoker is pre-heated - Always minimize opening the smoker once cooking has begun.
The heater element can be cleaned when cold with a very mild detergent and room temp water.
If you have the large 2 rack but are only smoking enough to use a small amount of rack space on only one rack remember that you are heating a whole lot of air - i have a couple (different size) wood boxes wrapped in foil to take up excess air space - this means less air volume to be heated and better heat control - DO NOT use cardboard boxes or other low temp combustable items in the box construction!
Make sure the house outlet you are plugging into is a 3-prong GROUNDED outlet on a 20 amp breaker.
Finally, make sure your smoker is level and remember there can be up to a 20 degree cooking temp swing in temp between the bottom rack and top rack (top rack 5-20 degrees hotter than bottom).
The heater element will cycle on and off during normal use.
Good smoking and enjoy.
Posted on Nov 24, 2008
Char broil model 4754512 electric smoker, you put wood and charcoals under the heating element?
You need to try Googling (Char-Broil)(4754512)(manual) to get correct instructions.
Aug 29, 2016 | Char-Broil Electric H2O Smoker
Where can order electric cord for H20 Charbroil Smoker 10yrs old
any whitegoods store will have this type of cord, just check what brand not what year...
Jul 18, 2010 | Char-Broil Electric H2O Smoker
Trying to figure out how to use my charbroil h2o electric smoker without a manual? can you help?
You can get a free PDF manual at Char-Broil,com and you can also talk to other users at and I bet you get lot's of help there.
Jun 24, 2010 | Char-Broil Electric H2O Smoker
I need a manual for a Char-Broil H20 Smoker. Is
Go to this link and you should see a download for your smoker on the right hand side of the screen.
Hope this helps.
Jun 21, 2010 | Char-Broil Deluxe Charcoal H2O Smoker
No inststruction manual for weber electric smoker
Does anyone know what the thermostat should read when smoking a brisket on the electric Char Broil H2O smoker??
May 31, 2009 | Char-Broil Electric H2O Smoker
Don't know where to put wood chunks in a Char-broil electric h20 smoker!!
Dip wood chips/chunks in boiling hot water for a few minutes if you're in a hurry or allow to to soak in tap water for about an hour if you have plenty of time. Either way, place the soaked chips around and under the heating element at the bottom. Don't throw out the water; heat it up and pour it in the water pan. Heating it up to boil will give your smoker a good head start. I've been doing that on my char-broil smoker for years.
Jul 02, 2008 | Char-Broil Electric H2O Smoker
Tripping Circuit Breaker
Same problem I have. I think the element or thermostat is gone. You will have to replace them. Here are the part numbers repectively:
May 27, 2008 | Char-Broil Electric H2O Smoker
Need electric plug for smoker
go to home depot and get the replacement element for the brinkmann gourmet smoker. costs $29.95. the replacement parts from charbroil (thermostat and element) will cost about $60.00. just remove the elemnt, replace it with the brinkmann and you're back in business.
May 10, 2008 | Char-Broil Electric H2O Smoker
Char-Broil Electric H2O Smoker Logo
540 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
