Question about Dryers
I opened dryer and found burned lint. There was about a half inch of material around the heating elements that had also started to burn.
  • 78 Answers
Clean the lint out and make sure the coil is undamaged. dryers need to be taken apart and lint cleaned out once in a while. also clean the exhaust line out real good as too much lint can increase the back pressure, not letting all the lint out of the unit.
Posted on Apr 29, 2008
Why is my miele t220 novotronic have a burning smell when working
If lint material has collected around the heating element this will happen. Locate the element and clean out all debris, lint, etc.
Sep 01, 2015 | Miele Novotronic T220 Electric Dryer
Kenmore Elite HE4 110.85872400Heating element repeatedly burns out with operational TCO and High Limit Thermostat operational. Common problem? Solution?
a dryer generally exausts max 15 ft each elbow/turn is 3ft,add it up and make sure that flapper outside is openning all the way no lint stopping it from opening.
Jan 08, 2012 | Kenmore Dryers
I have a Maytag neptune dryer model # MDE5500AY. I smelled a smokey and electrical smell tonight. What's going on? Lint catcher is clean and I also clean around dryer. House was built in 2004 and dryer is...
the fault is lint build up around the dyer element the element must be cleared of all lint after years of use despite having a catcher lint does get into the dryer in time it will build around the heating element and start to burn this is unsightly but more so very dangerous as it does cause house fires have the element cleaned
best of luck
please rank this advice if you found it helpful
sonic boom electronics australia
Dec 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer runs for about 10 minutes and then stops. If we hit the start button it will run for another 10 minutes. It heats up fine while it is running. When this started we smelled something...
Check for lint buildup on the "Hi Limit Themostat" located above the heating element. There is a thermostat kit that you can get and replace all three at once. This will make sure your dryer runs safe and up to its required operational limits. The lint buildup may cause the thermostats to get out of the tolerance. Here is a link to the thermostat kit.
The FixYa Team
Dec 26, 2010 | Maytag PYE2300AY Electric Dryer
Roper elctric dryer model RES7648EQ make grinding and scraping noise when i start it. Found a bra hook cought in drum on inside of dryer took it out now when I started it it smelled like the belt was...
belts dont really burn the main reason for buring smell is lint on the element did you take the whole barrel out? as 90% of the lint that burns is formed around the heating coil behind the barrel
best of luck sir
Dec 02, 2010 | Roper RES7648E Dryer
My gas dryer does not heat at all. I behind the lint screen was full of lint. I cleaned that out and still does not start to heat. Can you tell me what I should look for next? Thanks,
Hi
If your dryer is not heating, then check if the power cord is plugged into the wall. It may be loose or disconnected. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working. Now, check whether the heating element in your gas dryer is burned out by using an ohm meter to check for continuity. If the continuity is not there then you would need to replace the element. After checking the element, check out the thermal fuse to see if it's burned out. The thermal fuse is attached to the exhaust duct on the back panel of the gas dryer. It's usually surrounded by a black resin material situated in a housing made of white plastic. If the fuse looks like it
Sep 20, 2010 | Whirlpool GGW9200L Gas Dryer
My dryer keeps burning my clothes
I recently solved this problem on my dryer by taking apart the lint collection area. Some dryers allow you to do this by removing a couple screws surrounding the lint screen holder. Others require some dis-assembly of the top and front panel.
Once you have access behind or below the lint screen, use your hands or a strong vacuum (shop-vac) to clean out any collected lint that has fallen below the collection screen and settled in the exhaust duct. I pulled out about 100 cubic inches (~1.6 liters) of collected lint, cat hair, and debris that was obstructing air flow.
Obstructed airflow can cause metal parts near the heating element to overheat and scorch clothing and is a serious fire hazard.
Jan 13, 2010 | Dryers
Dryer powers up but won't start - smell of electrical burning. Is it the motor bushes? zanussi TC7103W
Electric dryers usually have a motor with a switch that prevents the heating element from being powered until the motor is spinning. In series with this are limit switches to prevent overheating if there is too much lint or too little air flow around the heating element. Also, the motors are induction or brushless. So the smell is coming from the heating element burning off some lint nearby as it reaches the high limit temperature and shuts off. This can be due to two conditions if we can assume the motor is running (has a switch that is closing to power the heating element). The most likely condition is that the drive belt is off the pulley or broken and the drum is not turning. You will be able to tell this easily by sounds or by opening the door to see the drum slowing down. If that's not it, examine the blower which forces air through the drum. There are a lot of variations, so look for air intake and drum exhaust ports that can be clogged with a sock, lint, etc.
Dec 12, 2009 | Zanussi TC7114W Electric Dryer
DEIX2 does not dry - cleaned out lint trap, disassembled and removed lint from around lint trap assy., still not drying
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jul 22, 2009 | Fisher and Paykel DEGX2 Dryer
Dryers Logo
282 people viewed this question
Top Dryers Experts
