Question about Pioneer DEH-P44 CD Player
Wire codes for a pioneer deh-p4400
I wanted to know what each wire color was a what it represented.(i.e. yellow wire is for the battery cable)
Right rear- purple wires
left front- white wires
right front- gray wires
left rear- green wires
BLACK STRIPE NEGATIVE ON ALL
red- 12volts switche
black- ground
yellow- 12volts constant memory
Posted on Sep 11, 2008
  • x113029 Oct 21, 2010
    Question: Is there a pinout schematic for same product? DEH-P4400
What's the blue wire for
Posted on Jan 26, 2012
Need to wire 2002 pioneer deh-p4400 to 1993 honda civix dx
Posted on May 10, 2012
I just want to know connection for radio wire color coding
Black is ground red is battery yellow is accessory as far as if you are installing a new stereo the best and cleanest way is to buy an install kit since they include wiring diagrams otherwise pick up a repair manual from your local parts shop they're around $25
Apr 12, 2014 | 2001 Nissan Almera Tino
What color wire is the power alpine
Almost all car stereos have standard color codes for power, there are Yellow, Red and Black, where Yellow is the direct current from the battery of the car (this always have power on it so don't let it near anything metallic or will cause a short), the Red if for accesory power (this only have current when the key on the car is on accesory mode) and the black is Ground.
Red and Yellow cables need to have power at the same time to power the stereo on, so if you want to test your stereo put the yellow and red cables together on the positive terminal of your car battery and the black on the negative, this should turn on your stereo.
Nov 16, 2013 | Car Audio & Video
2008 Jetta upstream O2 sensor
Right do you mean the wires to the O2 sensor from the loom or the wires from the plug to the sensor ,So i will explain what i know here and thats all i can do for you.On our europeon motors their is a 4 and 3 wire O2 sensor type,now on the sensor side of the plug their will be two wires the same colour normally white or gray ,these two wires are the heater circuit so should show a resistance with a meter ,now the coresponding two wires in the loom plug should read 12v with the plug disconnected ignition on .Now the other two wires are for the readings so push a pin through each cable and then with engine running plug connected you should read 0-point something which varies with engine speed somewhere between point 7 to point 2 varying with speed .if it stays around the point 4 mark then replace as its not working correctly ,you should be able to read the voltages with a code reader though
Jun 05, 2013 | Cars & Trucks
What are all of the colors for a 1994 Chevrolet silverado speaker wires, and what do they represent
Yellow is right audio and brown/black is right. This is all you needed right?
Nov 25, 2012 | Cars & Trucks
Stereo wiring on 1993 honda civix dx
I hope you like colors.. thats the speakers.. powers easy
black : ground .. red: hot wire to fuse box with hopfully a fueable link..( ever see them wires wit a fuse in middle) fuseable link..
Id run it all off that . make sure u find a power source thats always on. or it b 12: allday long
May 09, 2012 | Pioneer Car Audio & Video
Vga wiring i want to know what each coler wire represents so i wont burn my pc wiring my stuff into it
Here's some wiring diagrams:
First according to pin: http://hot-flash-games.com/web/vga%20cable%20pin%20connection-2875.html
And in this post you have pinouts according to standard color: http://www.diyaudio.com/forums/diy-projectors/30458-vga-pinout-wire-colors.html
db15 male
1)brown
2)red
3)orange
4)salmon
5)yellow
6)dark green
7)light green
8)dark blue
9)NC
10)light blue
11) purple
12)grey
13)white
14)black
15)brown/black
DB15 Female
7)light green
2)red
11)purple
13)white
1)brown
6)darkgreen
8)dark blue
10)light blue
3)orange
that's all oh yes you also have a ground wire from connector base to connector base.
Hope this helps. So from these two, you should be able to figure out witch wire is witch. Let me know if you need more detailed information.
May 03, 2011 | VIA ASUS A8V-E Deluxe K8T890 chipset...
I need to know where the battery temperature sensor wiring harness is located also what color wires on 2003 pt cruiser
This is located at the bottom of the battery tray and the wiring colors are: 1. Pink/Yellow trace 2. Brown/Yellow trace.
Let me know if you need more information.
Thanks
Jason
Mar 10, 2011 | Chrysler PT Cruiser Cars & Trucks
I have a after market stereo i want to put in my 1990 ford f150 but the wires dont match up how do i do it?
After putting in many stereos over the years, my suggestion is to get an after market wiring harness for the radio designed for your truck. They will have the same color wires for ease of installation. Remember that the black wire will be ground and the red and yellow wire will represent power. Here is a website you can go to to find the wire color code for your vehicle. http://www.modifiedlife.com
Oct 16, 2010 | 1990 Ford F150
Need wire diagram for pioneer deh-p4400 car sterio
Need wiring diagram for a pioneer DEH-P4400 car stereo.
Aug 07, 2010 | Pioneer Car Audio & Video
I need wiring color coding 4 pioneer deh 2050mpg? i know red is constant power.
Not to question you about the red being constant power but I have a pioneer deh-1600 car stereo and red is hooked to electric terminal controlled by ignition switch (on/off) and if your unit has a yellow wire that goes to constant power. The only problem with hooking up the red wire to constant would be if you happened to accidentally leave your player on it could drain the battery. Hope this helped a little. Good luck.
Oct 10, 2009 | Pioneer DEH-P2000 CD Player
Pioneer DEH-P44 CD Player Logo
3,591 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
