Question about Vacuums
I have a bissell flip it and it seems to be leaking water from the dirty water tank whilst cleaning the floor
Throw your Bissell Flip-it in the trash, its garbage.
Posted on Mar 02, 2012
  • 1,673 Answers
Either the valve asm. on the tank is bad, or the tank is cracked.
Posted on Apr 29, 2008
Bissell Lift off Cleaner - Big tank does not fill with dirty water- Clogged?
Check and clean the filters. Check you User's Guide or call the Consumer Care at 1-800-237-7691
Jul 31, 2014 | Bissell Lift-Off Deep Cleaner 94Y2
Bissel Pro Heat carpet cleaner is not suctioning cleaning water off of the carpet back into the tank. How can I fix this?
There is a knob on the base that says floor and tools. Make sure that it is closing when you switch it to floor, Make sure that the hose works when you use it too. That will tell us what the problem is.
Jan 30, 2014 | Bissell 1699 ProHeat Clear View Upright...
I have a blue bissell preheat 2x. While shampooing it will start to leak dirty water. When i'm done shampooing my carpets look even more filthy then when I began. Not sure why this is happening besides...
You should drain the dirty water, you should find where it is stock then drain it. If there's some leak, seal it with an epoxy. Thoroughly clean the inside and you will find there's a stock of old shampoo which causes water to become dirt.
I hope my advice help you.
Jul 13, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Whare does the dirty water go in the bissel 12 amp pro heat carpet cleaner
the clean water goes into a "Bladder Bag" that is located inside the tank. The way it is designed to work, as the clean water dispenses from the bladder bag, the outer part around the bladder bag fills with the dirty water. It never touches the clean water. Seems wierd, but it works! I hope this helps, if it does, please give feedback, as it helps me to gain ratings. Thank you! Remember to have your cleaners serviced every year by a qualified tech! Rene (The Vacuum Doctor)
Nov 06, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell little green leaks
the tank where the water is has a crack in it mostlikely
Sep 10, 2009 | Bissell 1425 Little Green ProHeat Handheld...
Bissell 2x wont **** up the dirty water
take the tank off and turn the unit on and see of there is section where the tank would sit. If so then the tank is not seated correctly, if not it is plugged with something.
Jun 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Spotbot is leaking...
Mine constantly leaked as well but I found that if I remove the container will the solution in it after every use it doesn't leak anymore. I store my container (upright - nozzle face up) under the sink with my other cleaning products and when I need to use the machine I pull it back out, pop it in and clean.
Dec 28, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Vacuums Logo
159 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
