Old Pentium III
I need to get into the setup to change the RAM configuration but it doesn't recognize the DEL key or the TAB key (which is displayed during Windows XP Home bootup). Is there any other way to do that?
Thanks,
Jack Null
  • 62 Answers
Are you refering to the system config utility at the begining of the boot up? I am guessing that is what you are trying to get into . .... Simply press F1 durring the first few moments of boot up and it should take you right into the setup.
Posted on Apr 29, 2008
Press DEL to enter Setup, Press TAB to display BIOS POST message"
Hello here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=M2V&p=1&s=24
Try to download the manual, by selecting your windows system.
Open the manual folder, and click on global for download.
You might need to upgrade the bios, to support windows 7, and certain harddrives.
You also need at least 2 gb ram, for the install.
Good luck
Jan 25, 2013 | ASUS M2V Motherboard
I have installed win 7. since my sys config is pentium dual core, 1 gb ram, 250 hd its very slow. i like to install xp, but i cant able to proceed to install earlier version xp. what can i do how to...
Hello !
When I encountered the same problem, I proceeded as following :
Enter BIOS setup using DEL or what other key your motherboard requires. Choose the ATA instead of AHCI on the SATA configuration. Apply changes then insert your CD/DVD in your CD/DVD-rom. Also make sure you have chosen the CD as your first boot device.
Aug 02, 2011 | Microsoft Windows 7 Ultimate for PC
How to fix 206 memory fail configuration
Turn Off the computer, open the case and re-seat the Ram/s. It's also important to clean the rams' contacts with a pencil eraser. If nothing is helpful, try with a new or working Ram. Let me know the outcome.
Good Luck.
Mar 13, 2011 | Intel Pentium 3, 1.2 GHz Pentium III...
My Computer is IBM Pentium III PC300 6345
Check your RAM thats it seated correctly , clear the system C-MOS and see if it boots up . Could be an error in the BIOS
Jun 03, 2010 | IBM Computers & Internet
Not so much a problem but I have an old Dell dimension with an 866 inteleron processor. I have 2 slots for Ram, each with 256 mb totalling 512, my question is can I replace them with 2 512's for 1plus gb...
Yes you can install 2 512 mb RAM for 1Gb in motherboard.But make sure both 512 RAM are same in configuration and frequency it is better you purchase both ram of same company.Then it works.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 23, 2009 | NEC Pentium III , 866 MHz Processor...
System board failure
You may need a new CMOS battery.
For now, you will most certainly need to reconfigure your BIOS as it is probably not recognizing your hard drive.
Your PC should tell you which key to use to enter your BIOS setup, such as ESC, DEL, F2 etc.  Press the appropriate key while booting to access the BIOS configuration.  From there, see if there is an option to set the hard drive to AUTO.
Also, it's possible that the BIOS is recognizing the hard drive, but your Master Boot Record (MBR) has been corrupted.  To fix this, insert your OS (windows) disk and load into a DOS command prompt via selecting the REPAIR option.  Once at your command prompt, type in FIXMBR, and press <ENTER>. It will warn that rewriting the MBR may cause problems...just continue.  Once successful, reboot your PC.
If that doesn't work, then you will probably need more help reconfiguring the BIOS, and may need to replace the small battery on your motherboard.
Jan 01, 2009 | R.A.M. Computers Compaq Presario 1075,...
No color I can't change rider or horse
The bulletted list contains the system requirements from Valusoft on this game:
  • Operating System: Windows® 98/Me/XP
If you are running win XP, then you probably meet the OS, Processor, and RAM specs.
  • DirectX®: 9.0
To find your version of direct x, click run and type dxdiag in the command box. The Direct X version is on the main page of the Direct X diagnostics page.
  • Processor: Pentium® III 700 MHz or 100% compatible (Recommended: Pentium III 1 GHz or higher.)
  • RAM: 128 MB (256 MB Recommended)
  • Hard Drive Space: 500 MB Free
  • Drives: 8x CD-ROM
If you are running Win 98 or Me, right click my computer and click on properties. The general tab of the system properties will tell you the CPU, Operating system, and RAM. (Almost all CD-ROM drives fit this minimum spec.)
  • Video Cards: 32 MB DirectX compliant video card (Recommended: 64 MB DirectX compliant video card), DriectX compliant sound card.
To find your video adapter, go to:
Start/control panel/system and on the hardware tab click device manager. Then click the + sign next to display adapter. Please report back what under display adapter.
(if it says Intel, Sis, or VIA, you have onboard graphics and the game will not work) You will need an upgraded video adapter to play the game.
Dec 30, 2008 | Computers & Internet
Which key to enter to bios to format pc IBM pentium III
del.. button on your keyboard old models may require F6
Nov 19, 2008 | IBM ThinkPad T23 Notebook
UpGrade
you could only upgrade the processor and RAM in this condition i.e.
you can only change your an upgraded p-III processor like 1.0 GHz, 1.1 GHz or 1.3GHz and
upgrade the RAM by changing to 256 in each slot.
that is all what u can do with ur pc
Oct 18, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Velocidad de PROCESADOR PENTIUM III
Si se trata de un portátil es que revela la actual velocidad del procesador cuando se ralentiza. Cuando no usas un pleno potencial transformador la computadora portátil que frena a salvar la vida de la batería.
Jun 22, 2008 | Intel Pentium III, 866MHz Pentium III-M...
Computers & Internet Logo
David Payne
David Payne
