Question about Vacuums
I took my hoover steam vac jr trigger apart and can't seem to remember how it goes back on?
  • 1,673 Answers
Maybe this will help:
Posted on Apr 29, 2008
Hoover steam vac smoking
Your problem sounds electrical in nature. I would take it in for evaluation / estimate of service.
Apr 22, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
How do I clean out the suction side of a Hoover steam-vac Model#f6020-900. I took all the screws out and still cant get it apart.I vacuum before using it, but it still seems to find more hair.
These don't come apart. Hoover makes a thin long tool that will allow you to stick up into this suction side to clean it or use a long piece of galvanized metal strip to slide up into it and clear away the hair.
Nov 26, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How do I clean the nozzle of my Hoover steam vac Jr?
No, this assembly can only be rinsed under running water.
Sep 29, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
MY hoover steam vac hand held hose cleaner leaks profusely
try taking a sharp knife and shaving a little off the edge of the plastic, or a small file if you can get to it, see if it is getting binded. If its getting stuck internally, you will have to replace the switch instead of risking takin it apart.
Jul 09, 2009 | Hoover F5810 SteamVac Upright Vacuum
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
The soap dispenser is supposed to be attched to the water tank. That grey piece, if it is round with 2 small ears on it is the metering plate, it controls the flow of water. It sits on the table that the tank sits on, insert it into the hole and turn to lock it in place.
Jan 14, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover steam vac jr. F5411
First take the guard off the nozzle and remove the nozzle being careful to not let the spring fly. Now pull off the little white tip of the nozzle which less than 1 inch long. Run a needle or fine wire through the main hole running parallel to the hose and make sure you can see it at the head of the nozzel end. It is best to also blow on it to make sure any dirt particles are gone. Even a speck of dust in your solution part of the tank can easily clog it. In 90% of these vacs, that solves the problem and I have repaired at least 50 of them in the past 4 years.
If that doesn't solve it then try this:
Take the impeller on the bottom out by flipping the tank part over, and clean it. Make sure it spins well.
These Hovver Jr Steam Vacs are long lasting and very effective in cleaning spills and stains. Our janitorial company has many of them and in 5 years only one of about 60 has finally been shelved for parts only. I have replaced a few nozzles and several tank latches plus filters, hoses, and the brush and capp on the end of the hose. An additional chore that is made easy with this is defrosting a freezer!
Nov 21, 2007 | Hoover F5411 SteamVac Jr. Canister Vacuum
F5411 steam vac jr. spot cleaner
There is one manual for the Hoover F5411 SteamVac Jr. available on but, when I opened it, I was not able to actually download a "copy" of the manual.
Instead, it looked like I would have to download / save all the pages of the manual as individual web pages (and then, if I wanted, convert them).
I went to (also a very good site) and, although they didn't have the manual there, I was directed to the main website.
There, under "manuals," I found the manual, available for download as a pdf file.
Happy steamcleaning!
Nov 18, 2007 | Hoover F5411 SteamVac Jr. Canister Vacuum
Vacuums Logo
48 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
