Question about Refrigerators
THE REFRIGERATOR AND THE FREEZER HAVE QUIT COOLING. HOWEVER THE FAN AND THE LIGHT IS WORKING. WHAT CAN I CHECK
  • 828 Answers
Check the back wall of the freezer compartment for snow or frost buildup. Fan running would indicate that the temperature of the coil which cools is cold. If you find a frost buildup on the back wall you more than likely have a problem in the system defrost circuit. You need a service tech.
Posted on Apr 28, 2008
I have the U-line 2015WCOL model. It was working fine and then it just quit getting cold. The light comes on but it is not cooling and the fan does not run. I cannot find a reset button anywhere. I...
Check the back wall of the freezer for excessive frost. A defrost system problem could be preventing the refrigerator from cooling properly. If you do see excessive frost on the evaporator in the freezer, you may be able to restore proper cooling in the refrigerator by storing your food in an ice chest and then shutting off the refrigerator/freezer and letting the unit completely defrost for about 24 hours. Leave the doors open for air circulation. After the frost on the evaporator has defrosted, plug the unit back in and see if the refrigerator and freezer will cool properly.
If there is still same problem then you need to replace evaporator fan.
Hope this helps.
Please feel free to ask us, if you have any further queries.
Shane
Apr 24, 2011 | Refrigerators
There is ice building up around the fan. If I don't keep chipping it off the fan the fan hits the ice and is quite loud.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 19, 2011 | GE Refrigerators
The freezer portion works, the fan and light in refrigerator section works but Fridge does not get cold
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Jan 25, 2011 | Amana ARB2257CSR Bottom Freezer...
Freezer fan quit working after ice took over (kids kept leaving freezer door open) we defrosted and the temp will not drop below 40 degrees is there a reset to restart the fan?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
No,
Probably wrecked the fan motor...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 31, 2010 | Samsung RB195ABBP (187 cu ft) Bottom...
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge quit working but freezer works
check to see if the back wall of the fridge is full of ice
if so that is an automatic defrost problem or check to see if your frezzer fan is blowing
Apr 17, 2009 | Refrigerators
Freezer works like frig-freezer lite only one working
ch the fan in the frige feel it if is blowing air .or is slow. you need to replace the fan moter.
Feb 06, 2008 | LG LSC26905TT Side by Side Refrigerator
Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Nov 30, 2007 | Maytag MTB2156GES Top Freezer Refrigerator
Not refrigerating
DO you have a thermometer to check the temp in both sections? MY first guess at the temp problem is that the fan has quit OR the vent betwen the freezer and the fridge is blocked. I bet on the fan being bad. Open the fridge door and hold in the little switch that operates the light. YOu should hear a fan running . If not, then the fan is kaput.. JOhnno.
Sep 16, 2007 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Refrigerators Logo
187 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
