Question about Sony Cyber-shot DSC-W30 Digital Camera
Sony DSC-W30 Is there anything past the factory reset method that will fix the stuck lens for this cameraor will I have to open it up and try to figure out for my self? Michael
  • 477 Answers
Goto www.digitalcamrepair.com and goto the self diagnosis page to get more info.
Posted on May 19, 2008
Suddenly the lens began going in and out and now it is stuck halfway out. Someone suggested banging it to unsyick it but that did not help. Our local camera shops do not work on Sony cameras. Any ideas?
The Lens may start going in and out when the Lens mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the issue, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required. For getting the unit serviced, you have to contact the Sony Authorized service centre or factory service centre. You can contact Sony here.
Thanks for using FixYa.
Jan 04, 2011 | Sony Cyber-shot DSC-W30 Digital Camera
The lens for my sony cybershot dsc-w310 digitial camera won't open completely.
It may have had an impact or a bit of grit/dirt may have lodged in it, try a tiny drop of sewing machine oil on a Q-tip and gently lube the lens protector
Aug 01, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
Sony DSC W30 digital camera, lens unit problem
Hi!
If you're sure you didn't damage the lens flat cable which connect to the motherboard, the focus of the lens unit you bought on ebay doesn't work. You can simply replace the back part (with focus) of the new lens unit with your old one. It requires soldering.
Tom
Mar 06, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
Sony dsc-w30 lense repeatedly goes in & out
It lens sensor problem.It might lens connector cable (it may be cut of) or need to clean focus sensor and terminal.
I have a Sony Cybershot DSC-W30 camera. This morning, I took a picture of my daughter, and turned the camera off. Right when I was turning it off, she asked me if she could see the picture, so I quickly...
MY LENS IS ALSO STUCK OUT. I pressed on the lens by accident while it was on. Now it won't turn on and the lens is stuck out. I tried twisting it left as recommended by aplynn09 but didn't work. SOMEONE PLEASE HELP!!!
Jul 16, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
When turning on power lcd says acess ,lens opens and closes . then lcd says turn off power and on again.also little orange light indicater at eye viewer flashes.sony cyber-shot dsc-w30.
I had the same problem. Your focus is stuck.
Try to free the focus from whatever (sand, dust, etc.) by hitting the camera. Start gentle, and if it doesn't work, hit it hard...the DSC-W30 is very rugged , that was my experience!
Greetings from Germany and good luck!
Jun 06, 2009 | Sony Cameras
Sony Cyber-shot DSC-W30 Digital Camera dsc w30 digital camera reset
If you want to reset DSC-W30, press Menu and go to Initialize, select it and press OK
Camera will be RESET and go to factory default settings.
Dec 01, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Sony cyber-shot dsc-w30 digicam problem
The lens due to some problems is not intialising ...... most commonly it may be dust particles getting stuck in the lens barrel ...... or the barrel itself is damaged ...... get it repaired from a repairman ..... as opening a lens is a difficult procedure ...and you may end up messing up the whole thing ......
Oct 26, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-Shot DSC-W30. The lens is in a "stuck" position
You have a bad lens, it prob. also says turn off and on again.
Jun 30, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Sony Cyber-shot DSC-W30 Digital Camera Logo
240 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
