Question about Jensen Car Audio & Video
Sirius DLP2500 tuner. Does this come with an atenna? If it does how long is the cord? (needs to be 15 feet from antenna to plug). If not where can I purchase an atenna?
mstr2kx
  • 102 Answers
SOURCE: Antenna extension
you can use another cable, with a connector between them, you can find these on ebay.
GoodLuck
Posted on Oct 20, 2007
SOURCE: Clarion & Sirius Radio reception
Did You pay Sirius for their service?
Posted on Aug 06, 2008
SOURCE: sirius satellite radio
You will need to get another sat antenna, and locate it somewhere either above the camper, or where the camper does not obstruct the antenna. Any store that sells sat radio equipment (Fry's, Best Buy, etc) will have the micro antenna. Install it either on the hood of the truck, or on top of the camper. You will need to run the antenna to the rear of the dash. They make Y couplers that will allow you to run both the OEM antenna and the extermal antenna at the same time, and it will not hurt the system to have both wired in at the same time.
Posted on Mar 13, 2009
MstrSteve
  • 26 Answers
SOURCE: Our new motorhome came with a sirius ready Jensen
Sirius Ready means that there is another piece the company makes that is for sale seperately from the reciever. you need to get the whole sirius system and it will just plug in and play through your existing setup.
Posted on Nov 18, 2009
  • 20 Answers
SOURCE: My sirius starmate says "antenna not detected".
The antenna that needs to be replace!
http://satelliteradiofix.com
Posted on Apr 01, 2011
Xm check atenna connection
If you are getting the same "check antenna" message with two different antennas, it is likely that the tuner itself is the problem. You can get just the mini tuner here:
http://www.tss-radio.com/products/xm-mini-tuner-replacement-home-dock
As far as the two plug connection, there are adapters available. Its likely a dual fakra connection, though I don't know for sure. At any rate, this is one adapter available. (I would call to confirm)
http://www.tss-radio.com/products/sirius-dual-to-single-antenna-adapter
Jun 27, 2012 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
How do i find the sirius id on the panasonic cq-hr1003u?
The radio does not have a Sirius ID - it is not built in. THe CQ-HR1003u is Sirius READY - meaning... The CQ-HR1003U can control an optional Sirius Satellite Radio tuner by Panasonic (item #133SRT100).
In addition to the Sirius tuner, you will need an antenna and subscription in order to receive Sirius Satellite Radio programming.
Thanks!
Sep 27, 2011 | Panasonic CQ-HR1003U CD Player
Hello, I am inquiring about a replacement antenna for my Polk Audio SR H1000 Sirius satellite tuner. Thank you, Donna Sebran
It sounds like you should be able to find a replacement antenna from any of your local electronics retailers, such as Best Buy, Radio Shack, etc. I would take your old antenna with you when you go to look for a replacement, though, to make sure that the plug that is on the end of the new antenna looks exactly like the plug on the old antenna, to be sure that it'll work for your needs.
Oct 17, 2010 | Polk Audio SR-H1000 SIRIUS Radio Receiver
I have a Siriusconnect Home Tuner and an XM Ready Receiver. Will they work together? What do I need to make the connection from the 8-pin mini DIN on the Tuner to the XM connector on my Denon AVR-587?
Not gonna work, sorry to say. You need the little two-piece "XM Ready" tuner unit (with antenna) to plug into your XM Ready receiver. Sell the Sirius Connect Home Tuner and buy the XM unit. XM unit still available at some Best Buy stores.
Sep 19, 2009 | Sirius Satellite Radio Receiver
Sirius satellite radio constantly shows "acquiring signal"
it could be the connection on the back of the reciever that could be bad. I would call sirius and see if your reciever is under warranty still, if not i can almost garauntee that your tuner antenna input is bad, if your antenna is brand new.
Apr 15, 2009 | Sirius Audio Players & Recorders
Radio does not work
put a wire in the antenna hole while radio is on if you get some reception then you know its your antenna do you have sirius if you do it sometimes it runs through your antenna if you dont then check your antenna wire where it connects to the antenna good luck.....
Dec 28, 2008 | Pyramid PDVD79 CD Player
Jensen MSR4050G Sirius Ready marine radio
I had the same problem and there are a couple of reason why you may not be able to get into Sirius Mode.
  1. You have the wrong type of antenna (it must be a Sirius approved antenna)
  2. You may not have installed the tuner (most Sirius ready units need require that you have a tuner hooked up to your unit to get satellite reception. The tuners are specific to your unit, so make sure you but the correct one. This is quite sneaky on Sirius’ part…but good luck).
May 19, 2008 | Jensen MSR4050G CD Player
Sirius vs. XM
Hello pdweidner,
The CN-NVD905U is fully satellite ready and is compatible with both Sirius and XM. To change services you will need to purchase and install a XM compatible tuner and antenna to replace the Sirius tuner and subscribe to XM service.
Best regards,
Ken
Go Ahead. Use Us.
May 13, 2008 | Panasonic Strada CN-NVD905U GPS Receiver
Antenna hookup 2007 dodge ram
Just take the fakra connector (plastic piece) off and it will be just like the sirius antenna end. Then buy a 10ft extention cable... I've just order mine and will have pics when done
Aug 15, 2007 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Car Audio & Video Logo
108 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
