Monitor is a solid green color when computer is turned on
  • 31 Answers
That's your desktop setting which you can change by going to the control panel, desktop, background, and then change the color or put whatever you have for a background. Also note the color and position buttons.
Posted on Apr 29, 2008
Hp monitor flashes solid colors
Hi there, the mode the unit is in is like self test. Try first to disconnect vga cable from pc and see if the there is notification "no signal" poping -up to see if the problem is not graphics. Anyway you can try to disconnect power cord from monitor and wait a while then try again power it on. If all this doesnt help it will be more then good advice to RMA it if still in warranty. Tnx
Sep 23, 2013 | Samsung Computers & Internet
Basic "background" colors are wrong:
Kathy...have you tried connecting another monitor to the same video card and computer? It could be...
1. Video card defective
2. VGA cable from computer to monitor defective...look for bent pins in plug.
The VGA cable from the computer video output carries three distinct colors...red, green and blue. Likewise one of these colors may not arrive at the monitor correctly or at all. The results being that all colors are incorrect.
Apr 13, 2011 | Westinghouse L1975NW Monitor
The color on my monitor has a green tint
If your monitor has just started showing an off color tint, try checking the video cable connection on the back of the monitor and the at the video connection on the PC. Make sure the connection is solidly connected and not loose. Wiggle the connection as you watch the monitor to see if the color changes... if so the connection is loose. Try rebooting the computer into safe mode and see if the color issue still shows... if not then you may have a video card issue, overheating can be a culprit
Apr 12, 2010 | Acer 22" X223w LCD Monitor
Solid green line from top to bottom
screen is going bad in your monitor. Whenever you get lines in the monitor no mattery what color they are, that means the screen itself is going bad and in this case since no parts are available, the monitor needs to be replaced.
Feb 06, 2010 | ASUS VK222U 22" Monitor
My lg monitor has turned green how to fix it
A common cause of a green screen is simply that the cable is not securely connected to the video card. Try to unplug the monitor cable from the back of the computer, and then plug it back in again and securing it with the thumb screws if possible. If that does not work, there may be a reset option in the monitor's configuration menu.
What make and model is your monitor?
Is it a solid green color? Does it change after a period of time being left on?
Mar 08, 2009 | LG Studioworks 700S 17" CRT Monitor
E19t5w screen problem
Hi...there,
Well, there are 2 things that caused thing problems... You've got a busted panel or you need to replaced a new AD Board.
Nov 30, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
No video
Try to check the light on the monitor. If it is amber, then check the video cable both from the back of the monitor and the tower. Try a known-good monitor. Check the diagnostic LEDS of the tower. There are four of them in the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem. If you have a solid green light on the tower, no beeps heard and no video, check the LEDS. If you get 2-4 light, a possible graphics card failure has occurred. If the computer has an external graphics card, open the tower, remove the card and put it back in. If still persist, try a known-good card. If it still does not resolve the problem, try reseating the memory cards. Remove and put it back in. If still no go. Then it's a motherboard problem.
Sep 16, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Xerox XL592DS Flashing Colors, Nothing on Screen
Sorry time for a new monitor you might open it up and look at the capacitors and see if any need to be replaced the bad ones will be domed on top normal is completely flat
Jun 19, 2008 | Xerox XL592DS (Silver) 19 in. Flat Panel...
Solid line completly across screen, monitor is brand new
Your comp's video card refresh rate (in Hertz, abbreviated Hz) may not be totally compatible with the monitor. Check the properties of your video card, and change the refresh rate (you may have to look around for it) to 60 Hz. This is a pretty standard refresh rate that works with just about every monitor. If it's already there, I'm afraid someone else will have to try and help!
Hope this helps, and please rate my answer, good OR bad.
Feb 04, 2008 | ViewSonic OptiQuest Monitor
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
