Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loading washer
After the load is finished and put in the dryer, the washer slowly fills with about 1-2 quarts of water, over a 24-48 hour period. What can be causing this? I can get rid of it by using the drain cycle.
I have this problem occasionally as well. I am sure it is the fill valve as suggested. However, I can shut the water off to the washer and the problem goes away for a while and I can leave the water on for months before it happens again.
Now if I can only get the spin cycle to work properly. The drom seems to be loose causing excesive wobble resulting in error code F7.
Posted on Apr 29, 2008
    President:
  • Whirlpool Master
  • 2,651 Answers
Your inlet water valve is not closing and needs replacing, in mean time turn water off between washings.
Water slowly runs in washer when it isn't on
dirt or faulty inlet solenoid diaphragm
simple fix is to turn the tap off at the wall when finished
Jul 18, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Stagnent water smell while filling
I found that running about a quart of white vinegar through a cycle with hot water and no clothes or detergent takes care of the musty smell. Vinegar removes detergent build-up.
Nov 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer not draining
sounds like the pump needs replacing located under the drum
Feb 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water backs up into washing machine after washing a load.
check your drain hose and drain pipe,if not that then i think your inlet water valve is not closing all the way,try it on cold only see what happens,then try on hot only see what happens,let me knoe what you find-mike
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified. 775f844.jpg
Dec 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
261 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
