SOURCE: to capture video acer aspire 6920 acer crystal eye webcam builti
you need to download a video capturing device
if your system did not come with one
the built in webcam is exactly that for messaging programs and taking snaps but they can be used for video and this is usually something you need to get on your own
debut is usually a pretty good site
please don't forget to rate me
SOURCE: how do i get my video to work
If your PC came with system restore then enter safr mode and restore to the date prior to uninstall. Alternatively visit the ACCER websupport and on entering your model and product sr. no. will also give you the same results............sodeep
SOURCE: Acer Aspire One AOD250 Netbook Built-in Webcam problems....
try this it sometimes works. 1. Start Registry Editor (Regedit.exe). START > RUN > (Type) REGEDIT (and hit ENTER) 2. Locate the UpperFilters and LowerFilters value under the following key in the registry HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6BDD1FC6-810F-11D0-BEC708002BE2092F} Write down the upper & lower filter valuse. Delete the UpperFilters and LowerFilters value (it's safe, and if could be restored later on if you have written it down, so don't worry)
SOURCE: No Acer video capture device was detected on your
you have to use the driver cd which came along with your device and install them and this will install the driver for your capture device and your hardware will be detected.
thanks
Click the drop-down menu on the toolbar to change the resolution. Click the gear icon to change the settings.
Click the camera icon to capture a photo. To turn off the Acer webcam, click the "X" button on the top of the window.
