Question about Watches
I have an Oster Golden A-5 clipper (dog clipper--I could not find the catagory on your list) with # 10 and # 15 blades. It has been quite a while since I have sharpened the blades, and I am not sure how to re-assemble the blades. I can put them together without any problem, but I am not sure how far back or forward to slide them before tightening the screws.
  • ajkennel May 06, 2008
    I did not receive an help, so I ordered some new Oster blades from Revival Animal Health www.revivalanimal.com
    They are running a May special of buy two get one free. I ordered two #10 and one #15. When looking closely at the new set, I can see the cutter does ride on the comb part of the blade. It covers the rail completely. Hopefully, this will help someone else.
    ajkennel
I did not solve the problem, but I doubt if you have an answer for me.
I will just use the blades as I have put them back together, and hope they are attached correctly on the comb part of the blade. There is an area on the tension spring that allows it to move forward or backward when the screws are attached to the comb part of the blade. I am not sure exactly how to adjust it when screwing it to the comb. If it is slid back, the cutter part of the blade will be set back. If it is slid forward, the cutter blade teeth will be nearer the edge of the comb part of the blade. The cutter still rides on the rails of the comb okay, but I am sure there is an exact position for proper re-assembly.
Thank you for any help you can provide.
ajkennel
Posted on Apr 29, 2008
What are dogs
I think you are asking about the game Watch Dogs? Watch Dogs Wikipedia the free encyclopedia It is cool, for 2012. Over 4 million copies were sold in its first week.
Jan 04, 2015 | Watches
I have a beautiful Budweiser hanging carousel lamp with the Clydesdale horses pulling the wagon It won't rotate anymore can you fix it? ses
You need to replace the motor. Check out this site. This is where I bought my replacement motor. http://www.atsclock.com/items/MotorMovement-clock_collector.cfm?catID=149
Dec 13, 2011 | Watches
Hii i have ak golden Watch & the golden watchband lost it color and now it looks like bronzed band. what do i nead to do, how can i fix it?
you had to bring it to jeweler for that your band had to be plated with gold . it is only gold plated that why it turnished. i hope this will helped you.
Sep 05, 2011 | Anne Klein Watches
Where can I get a 333 battery
In England
http://cgi.ebay.co.uk/5-Watch-Batteries-Renata-313-323-325-333-354-set-3_W0QQitemZ270535998336QQcmdZViewItemQQptZUK_Jewellery_Watches_WatchAccessories_SpareParts_SM?hash=item3efd33bb80
In USA - none listed on ebay, except for international (from England).
The 333 is quite an unusual battery, in that its one of only three with no other entries on a cross reference chart (i.e. not widely made).
Feb 24, 2010 | Piaget Watches
I have a bulova accutron with a 14KT gold case. it has day and date settings. there are Roman numerals around the outside of the bezel and the number e66289 mb on the back. is there anyway of checking the...
Since the serial number (E66289) begins with a letter, the watch was made in the United States. (Serials that begin with a number indicate the watch was made in Switzerland.) Look at the back again and see if there's a two-character code, such as M2. Compare the code against the list on the following link to find the year of manufacture: http://www.thewatchguy.com/pages/BulovaSerial.html
If it's an Accutron, visit this site to see if it's a 214. He's got a wealth of info on 214s! Good luck!
Nov 01, 2009 | Bulova Watch
After battery replacement of casio sea-pathfinder
If it has "AC" written on the module you may need to short between the AC point and + battery. Also check voltage of battery. It may just be too flat.
Jul 25, 2009 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
What size screwdriver is required to remove the screws on the braclet of a ladies accutron courchevel 26R28?
All screw heads in watch bracelets are usually 0.8mm - 1.30mm in diameter. In my experience screwdriver with the blade width of 1.00mm was good for unscrewing the bracelet screws in majority of cases. So, I would advise to buy a screwdriver with 1.00mm wide blade.
In case if you realize that the bracelet screws are a tiny bit smaller than your brand new screwdrivers blade - do not panic but use the sandpaper or any sharpening stone. Just a few strokes from both blade sides will reduce the width of the blade to the required size and you will be able unscrew the screws with ease.
In case if you brake the tip of the blade, use the same method as described above, just in this case reshape the blade. As the size of the blade is quite small, it is easy to do and takes very little time.
And,yes, the blade can be reshaped plenty of times, not just once or twice. In fact it can be reshaped and sharpened till you run out of metal.
Do not forget to rate, please.
Mar 12, 2009 | Watches
I have a cheap pocket watch that needsa new battery, and i do not know how to open it. does not look like the kind of back that wil pop off,could it be a screw on type?
Pocket watches are 99% with the back snap-on/sanap-off opening. Never came across the screwback. Get the knife with the solid blade, insert the blade in the groove between the case and the caseback and push it in quite hard using lever action (pry up). At the same time make sure the blade do not slip into the movement, as it will damage your watch.
If there is no groove between the case and the caseback, then watch must be opened by removing bezel (metal ring holding glass in place). Open the same way as for the caseback, just be VERY carefull, as any slip of the blade will leave the marks on dial.
Feb 27, 2009 | Relic Degrade Pocket Watch
Tissot t touch
there are sync instruction on the manual page on the web.
http://www.tissot.ch/data/usersmanual/138-en.pdf
1. Activate the Crystal.
2. Select the "units Mode".
3. Press and hold the "T" until it switched to "syncro" mode.
4. Now using the + and - move the hands to the 12 o'clock position.
5. Press "T" again to set.
Jan 12, 2008 | Tissot T-Touch T33159851 Wrist Watch
Changing a watch battery
I used a sharp penknife blade to remove the watch front by getting right on the base and pinching the glass off, (comes off quite easily) tilt the watch out of the case and see enough to prise battery out with a needle. The battery is a Maxwell SR920W or equivalent. Have ordered new batteries on ebay.
Oct 04, 2007 | Watches
Watches Logo
97 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
