Question about Dell Latitude D600 Notebook
Dell D600 - Linksys wireless router/adapter
I recently had a 2.4 GHz 802.11g Linksys wireless router installed along with a wireless adapter. I installed the driver software and adapter onto my Dell D600 laptop.
However, its not working. the laptop Device Manager does not seem to recognize the adapter and there is no power light coming on the adapter.
Dell is no help, says it is a Linksys problem. Linksys says its Dell's fault
Help. thanks
  • 56 Answers
Seems there is a problem with the Linksys since there is not any lights coming on. Did you plug it into a switched outlet in the wall? Does it work if you plug the Linksys into an outlet in another room?
If you can get it to light up, the way you will access it is through your web browser. Type in 192.168.1.1 into your web browser and a login in screen should pop up.
Posted on Apr 29, 2008
Will a dell inspiron laptop work wit a linksys 2.4 router
Please use a hardwired connection between the laptop and the router to check.
Mar 25, 2013 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
Where is the wps button on a linksys router
Depends on the on router. The button should have a picture of an antenna on it or say WPS. Pres it and the light will flash then press the wps feature button on the device you are connecting. If this is a Linksys EX0000 model it should be on front and center on the top of the router.
Nov 23, 2012 | Linksys 2.4 GHz 802.11b Wireless - B...
Fitted a Linksys-g 2.4 ghz pci adapter to my kids pc, take make their PC wireless, installed the correct drivers after researching what these were on the internet and all ok. Changed ISP and no longer...
If your modem(the device given by your ISP) connected the linksys router on WAN port just power down all devices and power on modem and make sure all lights are on and then power on linksys router. This should fix most problems. If no luck connect your computer to modem directly and check if you are able to log on to internet! If your modem is not working then your ISP is the best option to call!
Sep 11, 2011 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
(1) Can more than one WPC54G wireless notebook cards be used with a WRK54G router? (2) does the version matter? Thanks, Jack
Yes you can use multiple wireless card for this router and any version will do, any wireless adapter will work with the WRK54G fine.
Jan 15, 2011 | Linksys 2.4 GHz 802.11b Wireless - B...
How can I install my linksys 2.4 ghz adapter without its disc?
Router setup is not a rocket science !
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Oct 23, 2010 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
I have defined 2 networks, one for the G and the other for the N channel, only the one for the G gets connected
You have WRT610N dual band router . it works on both 2.4 GHz and 5 Ghx bands at the same time.
Both the bands are N bands.
2.4 GHz and 5 GHz band are capable of working on N signals.
Now on your computer you are able to see only the 2.4 GHz signals but not the 5 GHz signals.
To see the wireless signal on the computer , your computer should have 5 GHz compatible wireless adapter.
If you have 2.4 GHZ adapter on your computer then you won't be able to connect to the 5 Ghz signal.
Open the Device manager and under network adapters you will see the wireless adapter. Check if it is dual band wireless adapter.
Click here for more information
Aug 04, 2010 | Linksys WRT610N Wireless Router
I have a 2wire 802.11g usb wireless adapter. I
yes it would you just need to place the 2wire on a bridge mode then configure the linksys
Nov 22, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Adding a computer to wireless at home
1) Go to the computer that is connected directly to the Linksys router.
2) Open up Internet Explorer (or your favorite browser).
3) In the address bar, where it says "http://www...." clear out everything in there and type in the following numbers:
192.168.1.1
Press "enter" on your keyboard. This will open up a dialog box asking for your username and password. Try leaving the username blank, and type in "admin" for the password.
Now you're in a web page that controls your router. Look for the Wireless section, and make sure wireless is enabled. Check for wireless security as well, because you may need to enter a long number in your computer once it finds the router.
If you still need more help, feel free to ask.
Jan 08, 2009 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
Linksys router and Belkin wireless adaptor
Anne ,
I need to ask is the driver for wireless adaptor installed ?
Thank you ,
Styme = )
Jul 28, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Dell Latitude D600 Notebook Logo
240 people viewed this question
Alun Cox
