Question about Car Audio & Video
Phase Linear UV8
I need to know the brake by-pass code for this unit. Thanks
You need add a switch pink wire on one side ground on the other and when it turns on you have to flip the switch to on if dsent work just repeat until it does may take a couple times but it does take a second for the screen to turn
Posted on Jun 30, 2008
Just splice the pink wire into the ground wire and plug it in
Posted on May 28, 2008
Phase linear uv8
Hola Hope this might help a little. You may have to read. Sorry, I can\'t post too many pics or video, but this link should help I hope. The link provides details and goes over the wiring. If not, google it or check on YouTube.
Instruction Manual - Page 1
http://www.helpowl.com/q/Jensen/UV8/Technical-Support/phase-linear-uv8-schematic/9778
May 10, 2013 | Audio Players & Recorders
Linear phase uv8 and letting my kid watch movies while i drive
You can let your kidwatch DVD but not while your driving unless the screen is out of the view of the driver
Feb 17, 2010 | Phase Linear UDV9010 Car DVD Player
How do i override the emergency brake with remote to uv8
Look for dvd hack for that model. I see some on ebay
Jan 05, 2010 | Jensen VM9510 Car DVD Player
Unlock region code on my Phase Linear UV8
I had the same problem and I was able to fix it myself. call me and I can help you over the phone 951-334-2297 ask for George.
Feb 14, 2009 | Audiovox UV8020
Jenson Phase Linear UV8 sub input
u need to get a Y splitter to make that one female into 2 females so both the red and blue plug in. its like 5 bucks. one end is a male rca connection then splits to to female rca's
Jan 07, 2009 | Car Audio & Video
Phase linear uv8 parking brake problem
for the uv8 to bypass the parking brake to watch dvds you have to take the pink wire and put one end to one of the screws on a two screw toggle switch connect the other end of the pink wire to the other screw and connect that to the black ground wire
Mar 12, 2008 | Phase Linear UDV9010 Car DVD Player
Need to by pass
There are two ways of bypassing the brake sensor in a Phase Linear UV8:
1. ground the pink wire using a toggle switch;
2. Use the unit's built-in bypass software.
a. Select "Tuner" mode (AM/FM);
b. Press the "Setup" button;
c. With the use of the remote, press 5, 4, 3, 2, 1, and then press and hold 0 for a couple of seconds or until the menu changes. d. d. Display should show hidden menu. Among the options would be to turn ON the "Brake override";
e. Press th "X" on the bottom leftmost corner.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 15, 2008 | Televison & Video
Phase Linear UV8
I have same problem with same uv8 but i use remote to activate am/fm then hit setup on rem.enter 543210 and a new menu came up. ( listening for the beep after each 3 is pressed ) select the hammer in upper left hand corner of screen, select brake bypass to on, then hot the X near bottom os screen. this works for me it should work for you.
Jan 11, 2008 | Jensen VM9510 Car DVD Player
Phase linear uv8=jensen brake bypass code
from remote setup, 5 4 3 2 1 0(hold "0" for 4 seconds) let go. look for the brake override option and turn it on.
Nov 16, 2007 | Televison & Video
Car Audio & Video Logo
173 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
