that is common, your pushing air back into the other side and that pops the door. First adjust the ref so that the back sits lower than the front. It will have 2 5/16th nuts on the front behind the kickplate. going left will lower the back of the unit. After that get out some vasoline and lube up the flat sides of the door seal, this will help keep the seal moist and it wont pop open as easy
when you close the fridge door you create pressure in the fridge and the freezer door may pop open, close it more softly. or there may be stuff pushing against the inside of the freezer door
cleaned it and door was open for a while. closed door and and an hour later alarm went off. alarm now flashing and alarm light still on. temperature now at 53. freezer 33
I will tell you how I fixed this problem for a one time payment of $19.95. Or, go to appliancerepair.com and get the answer for free. There! That'l FIXYA.
Door gasket defective, check for proper seal around door (gasket should be flush against frame when door closed). Also other possible cause is that when you close the door to the ref, the freezer pops open just enough to cause ice to build up around door. Check drain plug inside evap area of freezer, and repalce door gaskets.
the door pops open because freezer and frig. are connected together via duct. air pressure builds when you swing ref door closed. apply a small amount of vasoline to the surface of the hinge side of both gaskets. this will aid in door closure. also the unit may be not level
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door...If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well. Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door. To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication. It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Adjust the feet to raise the front of the frige, which should be higher than the back. Therefore the weight of the door will keep it shut or at least cause it to shut itself if it pops open.
normal operation actually, gaskets are designed to seal door closed not to hold them closed, first off check the items on the shelves make sure nothing stick to far out preventing good closing.next the refrig should be tilted slightly back. to aid in the doors swinging closed( the should close automatically form 45 degrees.)ok for them to "pop" open so long as they close back shut. this works on top freezers and bottomr freezer refigs, sidex sides use a differnet system of closing, if htats the case look into replacing door closures(cams) located under hte door assy
