I have PAT tested both my Behringer Eurodesk and my behringer feedback destroyer and both have failed on earth leakage of 0.50 and 0.52 respectively. Both are just over a year old and work fine. Is it possible that these units work within these tolerances and/or I need to re set the tester to accommodate it? Regards, W Simpson
  • waz925 Apr 28, 2008
    HI THERE NO HUM OR NOISE FROM EITHER
    REGARDS
    WARREN
    YES I CHECKED. THE READINGS ARE CONSISTENT
    REGARDS
    WARREN
    Genius:
  • 3,587 Answers
Well..are you getting some sort of feedback or hum with this unit, with those ground leakages?
Posted on Apr 28, 2008
  • 3 more comments
  • Patrick Michaels
    Patrick Michaels Apr 28, 2008
    only way to determine that is to get the design specs from Behringer. Seems like the leakage is a little high..did you check all your grounds for solid connection?
  • Patrick Michaels
    just for my edification, those are in amperes, right? 500 milliamperes?
  • Patrick Michaels
    talking to Behringer right now..
  • Patrick Michaels
    we'll both know in just a few moments no doubt.
  • Patrick Michaels
Input gain pots not working the others ok
unfortunatly this would not be a user servicable problem and would need to go to the shop. Here is a link to Behringer contact page. Scroll down to the Locate a service center link. BEHRINGER Limited Warranty
Feb 26, 2015 | Behringer MX9000 EURODESK 24 Channel In...
Behringer sx3282 Installation
You can get the manual at: http://www.behringer.com/assets/SX3282_WebBrochure.pdf
Start with 1 thing and connect the output to your amp and speakers. If that works continue to add items. When it quits you found the problem.
Jul 21, 2014 | Behringer SX3282 Eurodesk Mixer
How do i hook up a feedback destroyer to my EQ,COMPRESSOR,COSSOVER
Put at end of the chain. In this order: (1) EQ (2) Compressor (3) Crossover, (4) Feedback Destroyer.
Dec 12, 2012 | Behringer Dsp1124p Feedback Destroyer Pro...
What is the best way to connect an external EQ or Feedback Destroyer unit to a Behringer PMP3000
Get an "insert snake" which splits each of two TRS plugs into TWO TS plugs.
Plug the TRS ends into the MAIN INSERT jacks and each of the "TIP" plugs at the other end into inpout jacks of the destroyer. Plug the "RING" plugs into the output jacks of the destroyer. You will need a snake with at least two sets of splits. I use a Behringer PROCOM compressor. For those the TRS plugs go into the channel insert jacks and the tips and ring plugs go to the in and out of each channel of the compressor respectively.
Jan 11, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer sx3242fx not working .i need circuit diagram .
Behringer will not release schematics unless you are an authorized service agent... however, sometimes you can make do with the few schematics floating around... What is the problem with the unit? They typically use a switching power supply and the schematics of those aree usually similar enough to repair them.
Sep 09, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
How do you connect behringer sx2442fx eurodesk sttudio mixer on acomputer in studio
WIthout a quality audio interface the answer is you don't... You need to procure an audio interface for the computer. The internal audio systems of computers are too noisy to get decent results. The manual for the mixer will show the typical studio connection with a suggested audio interface.
Aug 06, 2011 | Behringer Sx2442fx Eurodesk 24channel...
How o u hook up behringer feedback destroyer to a powered mixer
In order for this to work properly it must be inserted between the last pre-amp stage and the power amp. Can you please update this with the mixer that you are using? With the make and model of the mixer, I can provide you with a connection description. Since each mixer will have different labeling and options, it is not possible for me to accurately describe the connections without hte make and model.
Thanks,
Dan
Feb 02, 2011 | Behringer Dsp1124p Feedback Destroyer Pro...
Show me how to hook up the Behringer destroyer pro?
What are you going to hook up to?
Essentially you connect the power cord to power and connect outputs from say a mixer to the inputs using TRS balanced cables... and connect the outputs of the unit to your power amplifier.
Note taht there are MANY other possibilities using "inserts:on some devices.
Dec 02, 2010 | Behringer Dsp1124p Feedback Destroyer Pro...
127 people viewed this question
 Grubhead
Grubhead
