Question about Hotpoint HSS25GFP Side by Side Refrigerator
Hotpoint side by side door problem
The refrigerator side door will not stay closed. it acts as tho something is pushing it open and it stays ajar. gasket appears to be good.
  • 828 Answers
Check the refrigerator for level. Front can be a little higher than the back. Check for products that many be stored that may be holding the door from closing completely. Check the door hinges and make sure they are tight.
Posted on May 31, 2008
Door ajar light stays on as well as interior lights when all doors are closed
Most vehicle door open light works by a spring loaded contact switch. The switch body acts as ground. when the door is closed the switch depress disconnecting positive from ground. Seems that one of your door switch may be bad. Look for a rubber covered sitch on the door jam you should be able to remove the rubber cover to access the switch for a good inspection.
Jan 12, 2014 | 2004 Lexus GX 470
Hot point side by side with ice maker
My Hot point side by side has water and ice dispencer, when we use the ice maker the trap door stays open we have to close it by pushing it with our finger. We tried some lubricant on the hinges still stays open. We were wondering if there is a solinoid that acuates the door closed.
on Apr 30, 2008 | U-Line CO2075F-B Echelon Refrigerator Ice...
Refrigerator door will not stay closed
HI MANDY.normally the gasket dont's rare.i would think u'll need to check the bottom door difficult to get.u'll probably need to get a MANMADE ONE.good luck ali
Jul 12, 2012 | LG LSC26905TT Side by Side Refrigerator
Freezer door stays ajar after closing the refrigerator door.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 16, 2009 | GE GTS22KBP Top Freezer Refrigerator
Right side door pops open when left door is closed
Is this a new unit? This is caused by air rushing into the other compartment through a damper control. Most mfr's. install an air check valve at the bottom of both doors that will pop up to let external in, thus alleviating door blow out.
Apply a food grade silicone to the face of the door seals to add tackiness to to the surface. Follow link to purchase. A suitable substitute would be a little Vaseline.
Oct 11, 2017 | KitchenAid Architect KBFA25ERSS Stainless...
I have a whirlpool the refrigerator door will not stay close.
It shouldn't be pushing the door see the magnet that is used in the refrigerators are not repulsive.It doesn't get weaken that easily but what you can do is check if there isn't something bulging out of the fridge and pushing the door...take out all the things from inside and then try closing the door again. If door opens up again then definitely you have to look for a new gasket.
Jun 05, 2009 | Refrigerators
go to your local parts store and buy a can of PB BLASTER lubricant then open each door and spray the latch assembley really good then close and open the door 10 to 15 times. do this with each door. the door ajar light switch is located in the door latch assembley and cannot be seen so soak the latch assembleys really good so lube reaches the switch. these switches sometimes get stuck but this usually frees up the switch
Mar 25, 2009 | 2003 Mercury Mountaineer
Freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 25, 2009 | Amana ARSE66MB Side by Side Refrigerator
Freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Jan 18, 2009 | Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
97 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
