Question about HP Deskjet F340 All-In-One Printer
F340 Lo hablo muy bien, pero la contesta no se enquentra! It isn't there
  • gbvor May 21, 2008
    Just got home and found this from HP, I am adding it as some of it may be helpful for other problems.
    My question now is will this likely help?
    I am Hampton from HP Chat Support Team following up on our recent interaction.
    Solution:
    1. Download the Windows Installer Cleanup Utility from the web link given below:
    http://download.microsoft.com/download/e...
    2. Install this utility after the download completes.
    3. A shortcut for the Windows Installer Clean Up Utility is created on the Programs menu under the Start menu.
    To run the Windows Installer Clean Up Utility:
    Click Start, click Programs, and then click the shortcut for the Windows Installer Clean Up Utility.
    When you do this, you receive a dialog box that displays the following message:
    "Continuing further will make permanent changes to your system. You
    may need to reinstall some or all applications on your system that used
    the Windows Installer technology to be installed. If you do not want to
    proceed, please press the 'Exit' button now. Choosing 'Remove' will
    make the permanent changes."
    The dialog box lists all the currently installed programs that are
    registered with Windows Installer. Locate the software installer files
    you want to remove from the computer and click on remove and click Ok.
    Now, reinstall the software and check for the result
Te printer works with another laptop. I have to find a way to remove ALL of the HP software from this one and reinstall.
Posted on Apr 30, 2008
    Genius:
  • 3,587 Answers
Ahh...que lastima...
sounds like you may need to reflash the memory in the printer...
Let me see if that's even an option on that machine
Posted on Apr 28, 2008
  • Patrick Michaels
    Patrick Michaels Apr 28, 2008
    here you go..download this driver, and select the proper language, amigo..
    click here
Hola a todos, tengo un problema con el icono de la bateria de mi portatil. este desaparecio de un dia para otro y no hay caso de volverlo A Mostrar. en las Propiedades de la barra de tareas y menú...
lo siento, pero mi espanol no es muy bien. Para este problema, nescecitas vas al "Control Panel" > "System Settings" > "Power Settings". Perdon, pero no conozco este nombres en espanol. Tengo windows en chino y alman, pero no espanol :P.
Primero cambiar este cosas, y despues propiedades de la barra.
Jan 09, 2010 | Microsoft Windows Vista Home Premium...
Tengo una camioneta isuzu y se acelera y
Hola Ruben
No estoy seguro, pero tengo un Amigo 90 que le pasa lo mismo.  Según creo el problema está en los controles electrónicos de las válvulas (esos aditamentos que están a la izquierda del carburador, segun lo ves desde el frente, sobre la salpicadera derecha del auto)
No se como se corrige el problema.  Supongo que cambiando los controles de las válvulas.  Una cosa que puedes revisar es que las mangueras que comunican el carburador con esas piezas que te menciono no tengan entradas de aire por grietas por resequedad.
Si alguien más sabe una solución mejor, espero con gusto su respuesta.
Yo quisiera cambiar el carburador por uno 100% mecánico mejor
Oct 03, 2009 | 1993 Isuzu Amigo
Como puedo arreglar el audio de mi compuntadora
mi pc es ACER ASPIRE T160, no puedo escuchar el sonido, el problema es desde el comienzo no da sonido ni al prender
Sep 05, 2009 | ZT Group CISNET A7022 PC Desktop
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Jeep Liberty 2002 , se pagan de pronto luces y cepillos parabrisa
revise todas las conexiones a la bateria , los que van a la carroceria o negativos , todos con mucho detalle
Jun 17, 2017 | 2002 Jeep Liberty
EL VIDEO DE MI PC NO SE ME QUIERE ACTUALIZAR Y POR LO TANTO NO PUEDO VER LAS IMAGENES DE TAMA?O NORMAL. MI BOARD ES BIOSTAR P4M800. NECESITO SABER DONDE LO PUEDO DESCARGAR
esto es super facil
www.viaarena.com yo tube esa board y lo actualice por ahi,
creo que es unichrome pro, debes escoger muy bien las opciones, para que salga la que necesitas, mira las fechas y escoje la mas reciente, yo tenia el driver en mi pc pero hace poco lo borre, como ya no lo necesitaba.
ojo, le das a la opcion drivers, aparece arriba bien pequeño, luego te sale tipo de sistema operativo, escoges el tuyo, luego te sale otra pantalla, sigue los pasos, ve escogiendo tus opciones. es facil
Mar 14, 2009 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
Problema tarjeta sabrent
Hola, que tal yo tengo un problema también con la TV Tuner de Sabrent, pero en mi lap tiene Windows Vista y no me detecta audio.
¿Cómo le hiciste tu para que detectara audio al sintonizar la TV y capturar video?
roy_villafuente2510@hotmail.com
Dec 02, 2008 | Sabrent TV Tuner / Video Capture Box USB...
Problema con la resolucion de la pantalla
i format my ibm i series laptop an i can find my network adapter
Oct 23, 2008 | IBM ThinkPad i1200 1161 Notebook
42 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
