Hampton Bay 24750 Huntington III Ceiling Fan Logo
Posted on Aug 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The ceiling fan has a light attached. The chain that operates the light has snapped off. How do I get the chain out to re-attached to the remaining chain
tfelton3
Level 2:
New Friend:
  • Expert 183 Answers
  • Posted on Aug 10, 2010
tfelton3
Expert
Level 2:
New Friend:
Answers
183
Questions
Helped
63981
Points
490
You'll need to turn off the circuit breaker, take off the light kit, it only has 3 screws. Then look for the chain and note where it routes into the fan unit. If there is enough slack you can purchase a replacement chain at any hardware store and should be able to attach it with the little clip, reattach the light kit and turn the power back on
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
1helpful
How do I find the part of the ceiling fan that the pull chain is attatched to?
The pull chain is usually attached to one of the switches. There is one for the fan speed and one for the lights. Replacements can be found at a building supply store of lighting supply ..
Please Vote !
Wiring/Replacing pull chain ceiling fan switch
Sounds like it to me that the netual is not there.
2-wire pull chain switch wiring in a ceiling fan light kit
If you removed a switch there should be two wires. Connect one of the wires to each of the switch wires or screws. good luck
2answers
Ceiling fan will not turn off
There is 2way switch attached to this chain you need to replaced it.
Top Hampton Bay Dryers Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
