Question about Hampton Bay 24002 Ceiling Fan
Bought a monte carlo ceiling fan. removed old fan and found 3 white and 3 black wires, plus grounds. Cannot figure out how to connect the unit up. breaker controls all ceiling lights in master bath,2nd bath,and all three bedrooms. attempted to hook up per instructions, breaker popped. disconnected wires, capped all hit breaker and all but master bedroom work. Help, cannot figure out how to tie in existing wires.
  • 20 Answers
Try this:
* All 3 black together, with black and blue from fan
* All 3 white together, with white from fan
* All grounds (earths) together, with all greens from fan
Posted on Jun 17, 2008
Replacing fan. Wires from ceiling are grey pink white & bare copper. Wired to light switch. What wire connects to what? Ok so we just bought the place. The painters removed the old fans that had no...
Sounds like you have two hot wires. Just need to find out which wire goes to the wall switch. Try gray to black from fan,pink to black/white wire.white to white & green to green. If this doesn't work swich the pink & gray wires.
Feb 03, 2013 | Dryers
Wiring Hunter ceiling fan into old house. My house was built in the 60's an the wiring is confusing. I removed an old chandelier and I am putting a new ceiling fan in it's place. When I removed the...
Your copper, green wire are the ground. I beleave that the white is the power, and the black is your neg. to make sure i would use a wire tester to determen the power. From there white goes to white, black to black, and green to copper. I am not sure on the white/black wire it maybe another power. Look at your instalation manual it should tell you.
Hope this can help.
Mar 20, 2012 | Hunter Dryers
Just wanting to find which wires go where on switch of fan with light. i have old wire to loop into with new old wire brown / black new black red & green Thanks
I think u mean old cable has 2 wires, those were brown & black, new cable has 3 wires those were black=Neutral, red=Phase go to switch, green=Ground.
Thats it.
Aug 21, 2009 | Monte Carlo 5BY52MW Bayshore Ceiling Fan
Bought a hunter remote and can't figure out what wires to connect
The remote red wire should go to the black wire that goes to the light. The remote black wire should go to the black or black with white stripe wire to the fan. The white wire should go to both white wires from the light and fan.
The power in (black and white) should be connected to your power source black and white. Bare copper wire to ground on fixture
Jun 13, 2009 | Hunter 52" Ceiling Fan With Light And...
Wiring a ceiling fan w/light
To add to red54's comments:
This is what I believe you have:
- one source in the ceiling box (black & white)
- one donwline circuit in ceiling box going to another wall/ceiling box (black&white)
- on switch wire in ceiling box coming from your wall switch (black & white) -- this is the white wire which will be hot when the switch is truned on
Here's how it should be connected:
- all 3 blacks in ceiling box connected together -- no other wires in this bundle
- white wire (which is hot when switched) coming from switch connects to the black/blackwhite fan wires
- connect all reamining white wires together in bundle
- connect all ground wires together
It's that simple. Trick is figuring out, of the three cables in the ceiling box, which is source, which is downline, which is switch.
Maybe red54's procedure can help you figure that out.
May 09, 2009 | Hunter 22890 52'' Low Profile Plus Antique...
Wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Mar 24, 2008 | Hunter 20531 Vista Brushed Nickel Ceiling...
Hampton bay Windward III
Green and copper are the ground wires and I believe you can connect both these to the green wire from the fan (I only have the copper wire in the actual ceiling box). Black and Red can be treated as both black and both can be connected to the black wire from the fan (this is what I did in all my fans and it worked). White is the neutral wire and can be connected to the white wire from the fan (this is what I did in all my fans and it worked).
My ceiling box has the copper, red, black, and white wires. The ceiling plate for the fan I bought had a green wire. I connected the green wire from the ceiling plate and the copper wire from the ceiling box to the green wire from the fan.
Dec 29, 2007 | Hampton Bay 52 In. Black Huntington III...
Help with ceiling fan
black with black is for fan motor from swith red with red is for light fan from switch blue goes conect to black thats power for the remote white wuth white thats streat line is call comun or negative green withe green that streat conection for ground protection
Dec 26, 2007 | Hampton Bay 46175 Cameron II Plus Ceiling...
Hampton Bay 24002 Ceiling Fan Logo
97 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
