Yellow battery red accessory black earth purple right rear + speaker purple/black right rear - green left rear + green/black left rear - white fr left + white/black fr left - grey fr right + grey/black fr right - blue auto antenna blue/white rem amp brown phone mute orange/white illumination
RTM?
it means to add ink if new ink fails, the heads are packed up.
new heads needed or worse.
12 year old printers, mostly are all dead, now. why expect not yours. retire it we do. https://www.manualslib.com/products/Riso-Cz100-6909450.html
Click on Clarion (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Have
you misplaced your Clarion SIRCR Sirius Vehicle Installation Manual?
Would
you like a digital, searchable, pdf version of the Clarion SIRCR Sirius Vehicle Installation Guide? Follow this link to download a pdf
version of this manual.
I hope that helps. __________________________________________
You need to replace motherboard (P-98 error) of your printer the cost of it is to high, then I suggest value this repair or replace your printer.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.
it's more likey the faceplate, and where it makes contacts with the unit. if you try applying pressure and moving the detachable faceplate on while attached and it turns on, there could be a cold solder/loose connection on the board.
some stereos will shut off if the voltage drops below 12 volts. measure your voltage at the battery with the car at idle and stereo turned up and all accesories and lights on. you should have 14.4 volts with the car running. the batteries voltage is 12.6 volts so you have to have more than this to be able to maintain steady voltage to your components. if the voltage drops too low when the bass hits it can shut off your radio. a capacitor can help this and the safe number is 1 farad for every 1000 watts. if you plan on adding any other amps autotek and phonix gold both make a digital capacitor that is compact and go anywhere from .5 farad to 10. the bigger the cap the better. if your voltage readings are ok then check that your speaker output wires are not touching.
are you using an amplifier? if so, it sounds like you are using the blue (antenna remote turn on) wire instead of the blue/white (amp remote turn on) to turn the amp on.
