Question about GE GSS22JFMWW Side by Side Refrigerator
Fridge not cold frezzer not cold
Not cold enough help please
  • cpee Apr 29, 2008
    still not cooling all the way cleaned motor and bac of unit been 12hrs no ice motor is running in frezzer
  • 770 Answers
You will most like have to replace the main control board in the back of the unit it has been a common failure with your model
Posted on May 20, 2008
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
I have a ge refrigerator MODEL NUMBER GTS18FBSARWW AND THE FREEZER IS NOT COOLING completely
i have a ge fridge and the frezzer is working, but the fridge isnt keep food cold enough
Dec 28, 2010 | Refrigerators
Inside of frezzer is getting a frost build up and fridge is not getting cold enough.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 ..
Nov 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge not cold enough set at 8
okay if it is not cold enough you should check the frezzer temp, and then play around with the fridge that should help. I had the same problem
Aug 08, 2009 | Master Bilt Indoor Step In Cooler 70""W x...
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Frezzer not frezzing
if you have a old refrigerator it is probaly dying this happened to my parrents fridge a couple years of ago so they got a newer frigde and it works good but if you by a fridge make sure you by name brands
Jun 23, 2008 | Refrigerators
GE GSS22JFMWW Side by Side Refrigerator Logo
99 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
