Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Looking for a ring seal for a Kitchen Aide disposal. The part is # 114905. Apparently obsolete. Any suggestions?
  • 487 Answers
Try to contact these people.
They might be able to help you
LINK
Posted on Apr 30, 2008
Garbage disposal is jammed kitchen aide kwd-200a
Use broomstick:
Copy following link to repair, troubleshoot and replace disposal:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Add a comment as needed, or repost question with detail
Sep 07, 2012 | KitchenAid Batch Feed Garbage Disposal...
Tip
Garbage Disposal Leak from bottom of motor
If you have a garbage disposal and you find that it is leaking then you need to first of all figure out where exactly the water is coming from. The reason is that depending on where it is leaking from will determine whether it is easily fixable or if it would be better to just replace the entire garbage disposal.
With this is mind the best way to find the leak is to put the plug in place and fill the sink with water. Then place a food coloring or non-toxic dye into the water. Red often is a very easy color to spot under your sink. Then let the water down the sink with the disposal running. If the water runs down the side of the garbage disposal then you have a leak at the seal where the garbage disposal hooks up to the sink. This can easily be fixed by removing the garbage disposal, cleaning the old plumbers putty off of the ring and sink bottom, and then reinstalling the garbage disposal.
If you do not see any water coming down the sides, but it comes out the drain pipe, then the drain may be clogged and/or the seals for the drain piping are bad. The seals can easily be tightened. They may have come loose from the vibration of the motor or just the expansion and contraction that occurs from hot and cold water going down the drain lines. If the drain lines are clogged a garbage disposal safe drain cleaner can be used or the drain can be taken apart, cleaned and snaked.
If you have the dreaded water coming out of the bottom of the garbage disposal then you have the worst problem. The internal seals that are to prevent the water coming into the motor where the shaft goes through to the actual grinding chamber have deteriorated to the point where they no longer keep the water from coming into the motor. The water will make its way down through the motor and run out the weep hole or the reset button.
These seals are replaceable, but a new motor is needed for a complete fix on many garbage disposals. Because of this, many times the parts to repair this leak will be at least 75% the cost of a new garbage disposal. This makes repairing your garbage disposal, not a very good option. Replacing the whole unit is often the best way to go to make sure you have a fix that will last for a longer period of time.
That should cover all of the potential ways that your garbage disposal can leak. Hopefully you are able to pinpoint the leak and make the correct call to fix your leaking garbage disposal.
on Sep 23, 2010 | Kitchen Appliances - Others
I purchased a Blanco waste strainer #441099. It is brown plastic for a granite kitchen sink. My plumber could not use it. said it didn't have a ring that holds the disposal flange. There is a groove...
This strainer is not for a garbage disposal. The strainer for the garbage disposal comes with the disposal. If you bought two of these for the sink, then that's why you have one left. The disposal has its own.
Jul 23, 2011 | Blanco Sink Waste Strainer / Stopper...
We own a kitchen aide blender and it has started to leak. This jar does not come apart. do we need to replace the jar?
The Instruction & Recipe booklet for the Kitchen Aid KSB550, KSB560, KSB570, KSB580 5-speed Blender can be found here:
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209709225.pdf
There is no infomration to suggest that the blender blade could be removed for replacement of a seal
On page 27 of the pdf (page 24 if printed) there is contact information for ordering replacement parts. You might ask if the blade assemly can be ordered and replaced separtely but I believe you must replace trhe blender jar and blade unit as one piece.
Mar 13, 2011 | KitchenAid KSB560 5 Speed Blender
What is the difference between standard strainer and strainer for food erator? I bought a replacement sink wiht standard strainer, which does not seems to fit garbage disposal
If you need new sink strainer basket for disposal side of sink, you have to buy new disposal.
Each garbage disposal comes with its own strainer basket so that disposal can connect and seal.
First, the disposal strainer basket is installed, and then disposal lifts up and attaches from below.
A rubber gasket comes with new disposal.
Rubber gasket fits between disposal and strainer basket so that disposal seals correctly.
Photo below shows how disposal connects to strainer basket using steel connector ring under the sink.
I wrote tips for installing a disposal from days when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Feb 16, 2011 | Franke 900 Black Basket Strainer 900
There is water leaking down the electric wire at the bottom of the unit. What could cause this? the unit works just fine.
Once disposal rusts out, it needs replacement.
Usually if sink basket seal is broken or if dishwasher attachment is leaking, you can feel water near top of disposal.
Use paper towel at top to see if that area is wet.
If top area is dry, then water is coming from inside disposal, and disposal is rusted out.
If sink seal is still good, we used to buy same brand disposal and re-attach to same sink basket. That's the quick fix.
If this is inside your home, you probably want to install new sink basket that comes with disposal.
To install new disposal, also buy container of plumber's putty to seal sink basket.
Remove disposal.
Clean off old putty on sink. It will chip off easily.
Apply finger-thick amount of plumbers putty to sink opening.
Set disposal sink basket into putty and push down.
Tighten screws on bottom of sink basket.
Wipe away excess plumber's putty from sink so it looks nice and smooth.
Before lifting disposal into place, attach electric wires and attach dishwasher hose to disposal.
Use hammer and screwdriver to remove steel blocker located inside dishwasher stem ... the blocker is left in place if no dishwasher hose is attached.
Disposals can be different: But here's the usual sequence:
Lift disposal with one hand and hold level. Push up strong while rotating attachment ring until ring grabs bottom of sink basket.
If you cannot lift disposal with one hand while rotating attachment ring with other hand, use small bottle jack from auto-parts store. And put piece of wood between bottle jack and aluminum disposal so disposal doesn't break.
Here's how to handle tubular pipes below sink:
Any tubular pipe joint that moved while removing or installing disposal, has to be taken apart, cleaned and re-attached.
If washers are plastic, then clean and re-use.
If washers are rubber, then replace each washer with new rubber washer.
When reattaching tubular pipes, apply generous amount of rectorseal over each plastic or rubber washer for first-time seal of tubular pipes.
Nov 19, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Hayward Northstar 2hp pump that is leaking apparently from the Seal Plate. I replaced the Seal Plate O-Ring, Diffuser O-Ring, Impeller Ring, and Seal Assembly but it continues to leak. I used...
wow, thats odd. If you replaced every seal/o-ring and its still leaking its gotta be 1 of 2 things
You installed the shaft seal wrong- no disrespect, just a possibility
or there is a hairline crack somewhere you are missing...
Aug 22, 2010 | Hayward 1.5 Hp Northstar High Performance...
Dishes are still dirty. I have used every kind of dishwasher aide, half loaded it and dishes are still dirty, I let the water run until very hot before starting the washer. The washer says you don't have...
Suggest the problem may be a plumbing issue - likely substantially blocked drain system, so the dirty wash water cannot properly pump out but rather remains in the dishwasher.
Suggest getting a plumber in to "snake" out your kitchen drain system. You will probably notice your sink drains will suddenly work much better too...
Aug 02, 2010 | Dishwashers
Kitchen aid refigerator: door won't seal then lost power.
The GFI had becme stuck - yes we had plugged the fridge into the GFI which is apparently a bad thing to do. Replaced the GFI (and moved in away from the fridge) and all is well.
Jun 02, 2009 | KitchenAid KTRC19MKSS Top Freezer...
Badger 5 EX 3/4 Hp In sink Erator
the disposal is attache to the button of th sink by means of ring and clamps.
take a look how th ekitchen sink is mounted. the disposal is mounted the same way. you may need to get new rubber seal and a new plate for the buttom, where the screws is. you can take the ring to the near home center of plumbing store, and get a replacement.
you can use "plumber's putty", or " goop" .thing else will keep the water out.
Nov 05, 2008 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
