Question about Haier Washing Machines
Plastic screen on door cracked, Do I need a new door for Haier Washing Machine Model No. HW-C1460TVEME-U Can you tell me who stocks parts and how much a new door would cost.
Hi there, i had the same problem.. did you manage to get a replacement, if so where from?
Thank you
Posted on Oct 13, 2009
I have a complaint about washing machine model HW-D1270TVE ME i bought this machine 18months ago and it is now broke it cost a lot of money everything on it works except the drum dont go round like the...
What is the Warranty on machine? If it is 2 year warranty, then get on to them and complain, they will replace the part, or Machine. But Move Quickly as time maybe running out. But if it's under 2 Year, your in trouble I'm afraid.
Jan 22, 2018 | Haier Washing Machines
My haier hw-c1270 is not draining it is stopping the cycle at spin
pump might be blocked............clear pump........job done.....
Apr 08, 2011 | Haier Washing Machines
Haier hw-c1460tveme-u error 7 smelt like burning rubber the machine was on spin cycle when it stopped with the error the 7 way plug has been removed then replaced the machine will fill and drain but...
hello check the belt at the back it might have come off or snaped got trapped and started to burn. if ok then the motor could have burn't out or circuit board burn hope it helps
Apr 04, 2011 | Washing Machines
It is not draining the water out it is a haier hw-c1460tveme-0
Hi, you can drain the water by disconnecting the grey empty hose putting the end in a bucket and lowering the pipe flat and below the tub level, the water will empty under gravity into the bucket.
When its empty CLICK HERE to follow the instructions ho how to check and empty the filter of any debris, then try the machine again, is it still does not empty then suspect pump failure.
hope this helps.
Feb 12, 2011 | Washing Machines
My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Jan 07, 2010 | Haier Washing Machines
I have a HW-C1460TVEME-U haier washing machine,it sounds af if the bearings are going at the back is there anything i can do
It is a task that you might not want to tackle. You might be better off to have it serviced to keep your sanity.
Oct 29, 2009 | Washing Machines
Washing machine finished its last wash and is no longer working ?
All HAIER Washing Machines come with a 3 year parts and labour warranty - Ring them and get them to come and repair..
Apr 10, 2009 | Haier Washing Machines
Can't find Haier lint filter for HLP21E
My washer did not come with the Lint Filter. I contacted Haier Customer Service and sent them all the info they requested such as copy of receipt and etc. That was several weeks ago and Haier still says that they have yet to receive that letter. Or they say that due to high volume of warranty letters they receive, they have yet to process it. Anyways, I got fed up with the customer service or lack of, I started surfing the web for the lint filter and found the above site. The filter is very inexpensive and I got it in several days.
Apr 09, 2009 | Haier HLP21E Top Load Washer
Err1 : Door not properly shut
Err2 : Drainage error (clean filter check hose
Err3 : temperature sensor short circuit
Err4 : Heater error
Err5 : water fails to meet specified level within 8 mins check tap, water pressure
Err6 : motor error
Err7 : motor error
Err8 : water exceeds protective level check circuit
End : end of wash cycle
Unb : after the last rinsing cycle finishes spinning fails completelt due to unbalance of the laundry
only reason I know is i looked through the manual after getting it myself could be something to do with running a bath while washer on or something perhaps not enough water getting in if powder channel blocked
Sep 12, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
136 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
