Question about E-Machines M6805 Notebook
Power up issue
Ok, last night I completely shut down my laptop through Windows and turned it off. I unplugged it from the wall just to be safe in case if a storm kicked up. Anyways this morning I go to turn it on and I get nothing. No lights, no anything. Everything is plugged in how it normally is but I can't get a response from the computer. So I flipped the computer over and took the battery out, after messing with the battery I slid the battery back in at an angle and for a brief second the orange light kicked on but then it goes right back off again. So I held it back at that angle again and the light would kick on for a sec but back off. It won't even come on when the battery is put back in the slot how it is normally. I'm trying to figure out if its my power supply or a battery issue. Does anyone have any ideas? I've had my power supply plugged in all day and its ice cold, usually its extremely hot. I dunno, but if anyone does, please let me know.
  • 2 more comments
  • MrUpc Apr 28, 2008
    Thanks for the heads up. Do you think it could be something wrong with the power supply as well since it might not be keeping charge? This is just a new one on me and I need to get it back up and running as soon as possible.
  • MrUpc Apr 30, 2008
    For some reason the little plug-in icon on my touch pad is lit up very faintly, does this mean its charging? I'm kinda confused about what indicators on the touchpad mean what? Thanks for your help!
  • MrUpc May 03, 2008
    Ok, so now I have a new situation to add to the mix. For some reason I plugged my laptop in tonight and I got the blue led plug in light to kick on along with the orange led light on the front of the computer. The problem is I still can't get it to boot up, will it not boot up if the battery is completely dead even though it's plugged in?
    Sorry, I meant the blue led light on the touch pad with the plug symbol and then the orange led on the very front of the computer.
  • E-Machines Master
  • 5,568 Answers
You may have a contact issue in the battery compartment.
I don't think this will help but you can try using a pencil eraser to scrub the battery pack's contacts and, if they are accessible, the compartment's contacts too.
The situation (brief flash of LEDs) you are describing sounds like a battery pack on its last legs but it may be only that it has not been charging for a while.
Posted on Apr 28, 2008
  • Steve Allison
    Steve Allison Apr 29, 2008
    The typical arrangement is to have a small external power supply, often an inverter type that is quite light in weight with one end of a small case going to AC mains, the other end plugging into your laptop.
    These small supplies have some weaknesses but are not the end of the power supply chain.
    There is mostly a regulator internal to the system that does the final work of monitoring battery voltage (and system demands) to avoid overcharging of the battery pack.
    You can probably isolate the source of the problem (pack or external supply) with a very cheap multimeter which you will find useful for other things at home as well.
    The battery pack probably has more than two active contacts on it so the rated voltage may not be the first values you see when checking it.
    If the pack is rated at (for example) 12 volts DC, you may find a voltage between two points of (if charged) 11 (low), to 13-14 volts (charged) or some percentages related to these figures if the output votage is other than 12 VDC.
    If the external supply portion has failed, it could be repairable but would most likely have to be replaced. This may not be possible to determine with only a meter.
    If you can see exposed contacts on the system end of the supply, it is safe to check for voltage while the AC end is plugged in but may not give you readings that make sense since it may or may not be a filtered DC close to the value it would seem to be rated. This is because there may be a lot of high frequency AC mixed into the output.
    If the failure is in the internal section of the supply, it is not a repair one should undertake without the necessary technical skills.
My del studio laptop doesn't shut down
You could have a corruption in the script or a process that won't stop. Try holding down on the power button until the screen goes dark and all lights go out. That is a hard shut down without saving settings. After it shuts down (finally) power it back up. Hit the F8 key on your keyboard the moment your machine goes to the black screen before it can load windows. That is the safe mode. Move the highlight up to safe mode or safe mode with networking and allow it to continue to boot up. Then, when it's completed the process and windows displays that it is in safe mode, do a normal restart. That should resolve the issue.
Oct 22, 2013 | Dell Studio 1737 Laptop
HP pavilion ze4300 will not shut off.
Two things you can do, you can hold down the power button, keeping it held down, should power it off. The other solution is to remove the battery, this should cause the Notebook to power down
Feb 28, 2011 | HP Pavilion ze4300 Notebook
Laptop turns on then freezes
Shut it off, pull the battery out. Unplug all devices that you might have plugged into the laptop (anything USB, cards, etc).
With the battery OUT, and the power cord unplugged, hold down the power-on button for about 20-30 seconds. Reinstall the battery and/or power cord and then boot the machine into safe mode (hit "f8" white booting on windows operating systems to get into the safe mode menu). Try booting safe mode NO networking (top choice). Still locks up?
Possible issues are
1) Bad or failing HD
2) Failing RAM
3) Virus or drive issues.
Booting into safe mode should allow you to run a virus scan, then clean and defrag the HD and check for resource conflicts or "flags" for issues (control panel, administrative tools, browse until you find "Event Viewer" and click each icon in the drop down field on the left and read the "errors" in red on the right).
We'll need your OS and laptop model number as well as things like wireless devices or anything custom you've done or have installed.
Sep 05, 2010 | Samsung Computers & Internet
Downloaded windows automatic update stuck on 3 of 3 for last few days. tried last known good config does nothing, i always return to updating 3 of 3 cannot get my comp to do anything else. help desperately...
An issue has been identified by Microsoft that, after installing Windows Updates, a Computer displays a Configuring updates: stage 3 of 3. 0% complete message, reboots, comes back to that message again, and repeats the cycle. This problem occurs when Windows Update is attempting to install update 937287.
Follow this procedure to resolve the error:
1. Remove all connected peripheral Devices from the Computer.
2. Press and hold the power button until the Computer completely shuts down.
3. Unplug the power cord from the wall outlet.
4. Leave the Computer without any power for at least 30 seconds.
5. Reconnect the Computer to the power supply and then turn it back on.
6. Allow the Computer to start normally.
NOTE 1: Once the Computer has completely started into the Operating System, Windows Updates should automatically finish installing the update. If the update again fails to install completely, restart the Computer in Safe Mode (by tapping the F8 Kay at Start-up) and use the System Restore feature to return the Computer to a time before the issue started.
Click the Start -> All Programs -> Accessories -> System Tools -> System Restore.
NOTE 2: To avoid this issue, obtain and install update 937287 from the Microsoft Download Center separately from all other updates on the Windows Update site. Install the update that applies to your version of Windows Vista so that you can successfully install future updates.
For more information about this error, refer to the Microsoft KB Article ID 949358.
Good Luck!!!!!!!!!!!!!!
Dec 01, 2009 | Dell Computers & Internet
How to startup my computer designed windows vista?
turn it back on and while rebooting press f2 or whatever it says to get to the boot menu then go to safe mode it will turn on in a lower  resolution and delete the file. Your welcome
Nov 30, 2008 | Dell Inspiron 8500 Notebook
Toshiba Satellite: A135-S4427 / Won't shut down
by pressing the power button in, the computer has gone into standby or hibernate mode.
Heres what you Do:- press and hold the power button for between 10 to 20 seconds.
that should bring it out of hibernation.
if that does,nt work. remove the main battery.
when you,ve resolved the problem, run a disk-scan via your windows operating system.
Mike @ Compurepair.
May 12, 2008 | Toshiba Satellite A135-S4427 Notebook
ERROR MESSAGE READS...
Try starting it in safe mode. (Hold F8 after power on). If you get your icon screen go to start, run and type in msconfig. Click startup and disable all the items. Hit OK and try a normal restart. This error can be caused by a bad program starting up.
Aug 30, 2007 | IBM ThinkPad 600X Notebook
E-Machines M6805 Notebook Logo
151 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
