I am setting up my computer in a new office. When I try to reconnect I cannot get my printer and scanner to link up. I have a D-Link Air Plus Xtreme G. I have lights blinking on status and WLAN and solid light on WAN, but I have no lights blinking on local network for my printer and my copier/scanner.
  • 2 more comments
  • sterling300b Apr 28, 2008
    No, I have no software for the D-link. Someone installed it for the office, but did not leave the software
    Okay, I'm not sure what I am suppose to look at, but mine says AirPlus Xtreme G Dl-624.
    Sorry, but I am not very computer saavy.
    Thanks
    My operating system is XP
    So, should I plug the DSL right into the D-Link and then plug the D-link into the computer where the DSL line is at?
    I'm confused and this is all greek to me.
  • 4,102 Answers
Hi, Have you still got the software that came with it.
If so have you tryed re-installing
Posted on Apr 28, 2008
  • 3 more comments
  • paul proctor Apr 28, 2008
    Click Here
    Look at that and tell me if that is the same!!
    Click Here!!
    You can also try this one.
    What is your opperating system ie vista,xp
    Click Here!!
    This is a manual that might be helpful
    Let me know how you get on and if you need further assistance!!
  • paul proctor Apr 29, 2008
    hi have you solved the problem or do you still need assistance
    click here
    Hi here is the exact manual for yours ok hope this is some help
    click here
    Here is something else that will be of help to you.
    Let me know if your still having problems ok
When I try to copy using a HP C8180 from scanner bed. I get a message saying it is copying but never copies just freezes until manually shut down,
Hi
I had similar problems with my scanner (not HP) and turned out to be the driver, may I suggest checking that you have the latest drivers for your scanner, the following link has the drivers and manuals for your HP.
Trust this helps, regards Alan
Drivers ---> HP Support
Manuals ---> HP Support
Feb 11, 2015 | HP C1807A Ink / Designjet Printer Inkjet...
Why Oce TDS400 Printer and Scanner not Connecting to Controller
Installed Printer Driver Full Version Then All devices work and used it.
I share a link please visit and fill it.
Oc TDS400 downloads drivers manuals software firmware and safety data... and Techsupport Printer
Thanks,
Sep 08, 2014 | Office Equipment & Supplies
Microtek Scanner thinks it's busy when it isn't
Check using a new USB cable. Unplug everything else plug into USB except for mouse and keyboard. If not work. Un-install driver and software. Download driver and latest software. Reinstall printer using driver only. Then use Paint to test it.
May 05, 2017 | Microtek MRS-1200X6U ScanMaker X6 Flatbed...
It is a canon canoscan n340p/n640p, it use to work befor i have had it 4 ten yrs it was on win xp and work then just not. It went through paint shop pro as twain was ok but could use all the...
If you believe the scanner is still functional it is possible it won't operate with Windows 7. I have a laser printer like that and no updated drivers are available and in spite of using the Windows Compatibility function the printer is now useless.
You could try uninstalling the scanner driver and restarting the computer and then when you reconnect your scanner a "found new hardware" wizard should appear which can search the internet for a suitable driver.
You could also try using the Windows Compatibility function that in theory allows earlier software to be used - mostly unsuccessfully in my experience.
Oct 26, 2017 | Canon CanoScan N340P Flatbed Scanner
How come my pc cant link to scan doc???? this is an office pc. my pc at 1st can link to this canon IRC3220N , it can photostat can scan from the canon to pc into scan doc file. but for right now my pc...
try to reinstall the driver s for the printer/scanner ...and see if the issue is solved.....Another thing ....if the scanner is used by multiple computers you have to give the scanning command from the computer ...and not from the scanner itself...This way you will be able to import the scan result into the library of the program that drives it ..
another thing that may happen is the link to be broke ...so ..get to the fax and printers in the start menu ...and open it ..and redo the link ..by scanning for printers and choose it again from the list ..(by name ) ..and make it the default printer/scanner..
Jul 05, 2011 | Office Equipment & Supplies
Can I use the D-link Air plus DWL-G122 to make my printer wireless connect to my laptops and print wirelessly
If you are trying to use the wireless adapter to connect your computer to the network and the printer is connected to that same computer, you can share the printer
Apr 12, 2010 | D-Link AirPlus G DWL-G122 (NTWLDLLG122)...
Lost my cd to upload my printer to computer - Lexmark x6650
try this link:
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:134:0:0
Apr 14, 2009 | Office Equipment & Supplies
I have an HP Office Jet v40. No problems when I
Sannaer glass is dirty: Cleaning the scanner glass and white reference strip Follow the steps below to clean the scanner glass and reference strip: Remove any loose paper debris that may be present.
  1. Carefully clean the white reference strip on the underside of the scanner cover (or top cover) with a clean, lint-free cloth, moistened lightly with isopropyl alcohol. Clean only the white plastic part on the scanner cover.
  2. For those models that have a scanner glass, clean the scanner glass with a lint-free cloth, moistened lightly with glass cleaner. The HP Officejet K series and HP fax 1220 have a scanner opening instead of a scanner glass. Make sure that no debris is in the scanner opening. Use canned air to gently blow dust and debris from the scanner slot.
  3. Replace all removed components and close the unit.
  4. Plug the power cord back in and turn the unit back on.
  5. Make a copy to verify the lines are not present. If lines are still present and there is nothing visible on either the scanner glass or the reference strip, the unit will require service.
Instructions are on this HP link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu50325&lc=en&dlc=en&cc=us&product=60630&rule=30380&lang=en
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
jasbo
jasbo
