Question about Motorola Mobility RAZR V3
Speaker only My phone only works with speaker phone?
  • kittycat10 May 11, 2010
    sorry to sound daft here my phone has the same problem (only works on speaker) if I do the reset will I lose all my phone numbers, music and photos? thanks
When I go the the initial setup menu, there's no selection that allows me to type in ##332284 so I couldn't follow the instructions from there - meaning, all I could do was RESET the phone.
But no worries: A simple RESET fixed the problem, for me at least. Thanks a million! The guy at the phone store was telling me I needed to buy another phone which meant starting my contract over again for another 2 years.
Posted on Jun 08, 2008
Happened to me, i had to reset my phone, then go into the setup menu.
type ##332284, the 4 should not show up, press clr then top left. it should now say FTS on the top of the screen.
press top right, keep pressing top right till it says ServOpt: at the top , and a whole list of other things.
go down to AudioOpt: ; make sure this says AUTO. use top right to change if not.
when finished, press clr,clr,clr then top left.
Posted on Apr 29, 2008
Speaker not working
Hi, when a speaker of the phone is not working, it can be caused by either dirt on the phone or the speaker needs to be replaced. You can open the phone, clean the speaker and see if it will work.If it doesn't work,that means, you will replace it with a new speaker.
Take care.
Jun 17, 2010 | LG KG290 Cellular Phone
Speaker on phones cut out both when I talk and
open the phone, clean the surface of the speaker, read the speaker with a meter, if it is working, put it back on and couple the phone but if it does not work replace the speaker with working speaker.
Jun 02, 2010 | Vtech Cordless 6041 Phone
The earpiece doesn't work on my Samsung Rugby. I can answer a call, but need to use speaker to hear the caller. The volume works fine.
Dear, your phone's head speaker is not working so you just need to go to a mobile phone repairer to change your speaker. Speaker is not expensive, If you want to change speaker yourself then its is not very difficult to change, you just need to put new speaker in the place of speaker.
Thanks
May 07, 2010 | Samsung Rugby SGH-a837 Cell Phone
The front speaker stopped working. Only the
Hi
To get the front speaker to work again you need to get an expert to change it for you.
Cheers
Mar 03, 2010 | Samsung SGH-t209 Cellular Phone
Internal speaker not working, on speaker phone can hear conversation but when speaker phone turned off get no sound from the earpiece
No need to worry thats means the internal speaker is no longer in a working condition. You just need to replace the internal speaker and after that every thing will b perfect. But before replacing the speaker just press it little on the top some times the speaker gets lose and stops working so check it before replacing. I hope this will help in solving your problem.
Dec 10, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Pan KX-TG3032CS: Handset has dialtone on Speaker, not on Talk. Handset works OK otherwise.
Made phone call on Speaker; worked OK.
(Had to phone the library anyway; good test.)
Took handset apart, determined normal ear speaker was OK.
Disconnected Speaker - never used it anyway.
Switched ear speaker wires to Speaker connection. Soldered connection.
Phone now works fine; just press Speaker rather than Talk.
No parts, no cost, & a working phone. And if there's a problem I can simply reconnect the Speaker & use it that way.
Sep 10, 2009 | Panasonic Lands Phones
Speaker won't work when answering phone normally.
try to custom reset the handset
*2767*2878#
& . OR
*2767*3855#
this will erase ur contacts on the phone and perhaps sms;s too that are stored on the phone memory, but it may just make the speaker work too.
if it stil fails, change the flex connector and ur phone speaker will work fine.
BR
Jun 09, 2009 | Samsung SGH-D900 Cellular Phone
Flip up ear speaker stopped working
Sounds like the ear piece connection between the two halves of the phone has been broken. Your "speaker phone" function should still work because the sound comes from the back of the main body of the phone. To the best of my knowledge, this can't be fixed. You will need a new phone. I hope this helps.
Mar 29, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Main speaker not working
Just press and hold the "phone" green buttom for about 2 seconds. The main speaker is enabled. The same procedure works when during a phone call, to enable a hands-free operation, or when listening to windows media player.
Sep 14, 2005 | HP iPAQ h6315/h6365 Pocket PC
Motorola Mobility RAZR V3 Logo
132 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
