Question about Whirlpool GS6SHEXNL Side by Side Refrigerator
Side by side refrig, exterior walls of freezer are suddenly hot to the touch
ANY SUGGESTIONS?
  • Whirlpool Master
  • 5,568 Answers
Your subject line was too long; 'exterior walls of freezer are . . .' ??
Posted on Apr 28, 2008
Refrig won't cool on either freezer or refrig side. Confirmed manual settings & allowed 24 hrs for cooling. Is there a reset switch somewhere other than manual switches inside refrig?
check that the compressor is working by feeling for motor vibrations at the compressor, hot compressor unit or hot fins or back wall of the fridge
if there is not heat then the compressor is not working
call a technician as it could be a start/run capacitor failed or compressor seized
get a quote as some compressor replacements cost as much as a new fridge
check that the utility power is getting to the fridge/freezer
Jul 10, 2016 | Refrigerators
Hot center wall in refrigerator
This is more likely to a defrost heater sticking on and not turning itself off, could be either a timer, board or defrost temperature sensor issue
Apr 03, 2014 | Refrigerators
Freezer has warm spots. All around freezer is hot to the touch. Compressor is hot, coils are clean, condensor fan is running.
Thats normal.
The condenser coils are located just inside of your exterior cabinet walls on the sides and top.
So the freezer gets cold inside and heat has to be released from the condenser coils.
If this is something new, you may have a problem with the defrost timer
Sep 11, 2011 | Kenmore Side by Side Refrigerator
Front of inside wall between freezer and refrig is hot to the touch?
it is normal on the wall ther is heater to dry or to avoid the moisen the wall during ref is cooling
Apr 06, 2011 | Whirlpool Refrigerators
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
Sep 29, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refridgerator top freezer exterior wall hot
Hi.........
Folow these steps. It's worth a try.
1.Pull the fridge out from the wall and unplug it.
2. Clean the dust and lint off the compresser and everything else.
3. Also clean under the fridge.
4. The frame around the freezer door should cool down.
If the cooling fan was stuck , that may also be a cause for your refrigerator wall becoming hot.Check that too.
Hope My info is useful....Bye
Sep 19, 2008 | GE Profile PSW26P Stainless Steel Side by...
Exterior side walls VERY hot
Hi wjjlaw,
ngafm at your service,
Is the hot side th open side or against the wall or cabinet side?
Have you touched this side before in he two years you have this appliance? Or is it that you just noticed it?
And if you can keep your hand on that spot for a long time it is not so hot only warm? If it is not burning your had it is probably just the characteristic of that fridge!
Check if the freezer part is full to the top and packed full.
Freezers can not be so full that you cover the cold air vents usually found in th rear of the freezer.
My advice is only a trained tech can remedy this problem, this time!
If I were there I'm sure I could nail it down!
You need hands on service!
Bless You ,
ngafm,
Please give me a good rating before you sign off.
Thank you.
Sep 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Outside of refrig/freezer hot
Heat exchangers for rejecting heat to air are built into the outside walls. This is normal. Just make sure you have enough clearance for free air circulation around it.
Apr 20, 2008 | Nor-Lake Norlake Refrigeration 4' x 6'...
Whirlpool GS6SHEXNL Side by Side Refrigerator Logo
127 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
