Question about Roper REX4634KQ Electric Dryer
No heat i have a roper front load dryer model number is REX4635EQ2, had heating element tested and is fine, but i still have no heat, an other suggestions. Thank you, Donna
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 5 Answers
There is a cheap way you can fix this which I have been doing you years!! Yes i said years... First of all the heater elements are expensive so what i did is opened up the back and found the heater element and un screwed it. you see a bunch of springs and you will see that there is a break in the spring. all you need to di is overlap the spring and replace back in. Now replace the back shield and connect back the hose. and plug in. Now each time i do this it last for about a month as long as you don't over fill the dryer. NOW THE DANGEROUS PART! I have had to do this so many times that i no longer put the shield back on so i can easily get back to the element and patch it which does leave me open to lint getting into the coils and burning up..... This has never happened be aware of this. THE BEST THING I EVER DID FOR THIS DRYER IS TAKE A BLOWER AND BLOW FAST AIR INTO THE HOLE IN THE WALL AND THIS HELPED SO MUCH!! THERE WAS A LINT STORM IN THE NEIGHBORHOOD BUT THIS HELPED A LOT!!!!!!!!!!!!!!!!!!!!!!
*** UNPLUG THE DRYER BEFORE ATTEMPTING *** PLEASE
remember it would be bad business to make the element last forever but you can extend the life for years doing this!!
Posted on Aug 28, 2008
  • 550 Answers
Most common cause is burn out of the thermal cut-out. These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
Clean the exhaust ducts all the way to the outside wall, lots of vent hoods block over time. then examin the exhaust duct for devices that look like this no heat - 67529a5.jpg or like this with wires connected to the terminals. there may be 2(hi lo), test with a flashlilight bulb or meter conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
Posted on Aug 27, 2008
Roper dryer takes 2 cycles to dry clothes. How do I look at the heating element? OR since it is still heating, just not quickly enough, could it be something else? OR does it have 2 heating elements?
First of all, unplug the unit before working on it. Be careful inside a fuse box, dangerous voltages. It's usually safe to change fuses or flip a breaker so long as your not in a wet location. Most dryers run the heating element on 220 volts, meaning you can either have one larger breaker or you could have 2 smaller breakers or fuses. If that is the case, possibly one of these breaker "legs" has tripped. Check that first. I would sooner think one of the heating elements are open or "not heating". I would look up the Roper Model number and search for the heating elements section. Some do have a thermal fuse but I think that would cause both elements to quit. Take a look here: https://www.youtube.com/results?search_query=roper+dryer+heating+element+replacement
Dec 20, 2017 | Roper Dryers
No heat in dryer
Brian;
there is a heating element that comes on/off during the cycle it's is located in the back, bottom of the dryer...easy to remove. Unless it's a newer front load model... which I personally hate :) because you access the FL model from the front.. but it's just like a heating element in a furnace, test it w/ a nolm meter, you should be able to see the break in the coil....
Mar 15, 2014 | Samsung DV448AEE Electric Dryer
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
My roper dryer REX6634pq0 does not heat!!
there is a thermal overload switch that activates the heating element. This switch will be located in the area of the element itself. It is designed to shut off the element in the event the element itself reaches a temp beyond it's designed temp. It is a safety device. If the switch is out it will not allow the heating element to activate. This switch looks like a silver button and has several wires going to it is about the size of a dime. Replace this switch and you should be good to go
Dave
Mar 17, 2010 | Dryers
Roper dryer won't heat up. Model REX4635EQ2. how do you change the heating elements?
Before you start diagnosing your problem, ascertain that you have made a proper and positive heat selection on the control panel, then proceed.
Below is a link courtesy of www.repairclinic.com, which shows disassembly/diagnostic procedures.
http://www.repairclinic.com/Dryer-Electric-Whirlpool-Style-Version-2-Appliance-Diagram
A volt-ohm meter (VOM) will be helpful in diagnosing most issues.
http://www.ehow.com/how_2076998_use-voltohm-meter-safely.html?ref=fuel&utm_source=yahoo&utm_medium=ssp&utm_campaign=yssp_art
Purchase a VOM
http://www.omega.com/ppt/pptsc.asp?ref=HHMA&Nav=vhtj06
Below are the next 4 common failure modes to check.
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If all the above checks allright, then proceed to the next steps below.
Thermal overload/cutoff thermostat.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%
3d%3di2651&PartID=2651
Cycling thermostat.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%3d%3di2893&PartID=2893
Motor Centrifugal Switch.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%3d%3di2584&PartID=2584
Heating Element Connection Wire.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%3d%3di3140&PartID=3140
Timer.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-REX4635EQ2-%3d%3di548371&PartID=548371
Sep 21, 2009 | Dryers
I have a Roper dryer and it just turns off we can
first thing to do is to find out whats wrong with the cord, get to the part of the cord that goes into the machine, wires are loose. a 220volt dryer will not heat if one of the wires are loose. you need to get into machine and make sure wires are tight. this is also a safety hazzard, do not leave machine plugged in until problem is solved
Sep 02, 2009 | Roper REX4634KQ Electric Dryer
Warm heat..clothes not drying
john there is only one heating element.ither it works or it dosent.when acustomer complains of low heat or long dry times 99out of100 its the venting or the dryer is blocked with lint.remove the dryer from the venting and try a load.if better clean house venting.you .........if not better you should have a great air flow leaving the dryer so if not drying well with venting off.take dryer apart a clean all araes that air is moving,where lint can block that flow.god bless .tom
Jan 01, 2009 | Roper REX3614KW Electric Dryer
No heat
The most common cause of no heat to an otherwise functioning dryer is failure of the thermal cutout.
As well as the electric line fuses in the circuit there are devices that look like this 13889aa.jpg or this 284f4e0.jpg screwed to the exhaust air duct with wires to the terminals
, inside the dryer. If there is a lint blockage in the duct or fan or outside vent hood, the air tempoerature rises and melts out this thermal cutout (also thermal fuse, heat protector, heat cutout & any other names different makers use) before causing a fire.
Test with an ohmmeter or battery and lamp bulb, conducts good, no conducts fail-replace.
Despite the number of models of dryer there are only a few thermal fuses, and the local parts guy WILL have the blown one on the shelf, as GE if not as roper part.
Whil the dryer case is opened is a good time to vacuum out the exhaust vents, fan impeller, and vent hood. ounce of prevention and all that
Jul 26, 2008 | Roper REX4634KQ Electric Dryer
Roper REX4634KQ Electric Dryer Logo
240 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
