Question about Samsung Weather Resistant Security Camera SSC-12C
Samsung ssc-12m need schematic
  • w5ukf Mar 23, 2009
    I too need the schmatic for the Samsung SSC-12m security monitor.
3 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Samsung B/W Observation System - Model# SSC-12
The blinking green power light in front of the monitor - indicates 2 possibilities:
1. no video signal received (highly unlikely - 3 cameras); or
2. most likely internal monitor problem with part(s) of its circuitry and the auto-protect/shutdown is activated, hence the powering on and shutting down (blinking green power light). The clicking sound is most probably a relay inside the monitor that switches the power on and off.
A few thoughts:
1. The cameras get their power from the monitor. So if the monitor goes bad, the cameras will also be inoperable. And the same also holds true if any of the camera develops a power problem, the monitor would react;
2. The VCR is a separate unit and gets its video INput from the monitor and would not be an issue at the moment.
Things you can try:
a. Remove all the RJ11E ("Telephone" type) camera inputs and plug them back one by one just to determine if it's a camera problem and the monitor is simply reacting; or
b. Use a different monitor of the same type of input/configuration connectors.
Hope this be of some idea/help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Oct 26, 2007
  • 15 Answers
SOURCE: Looking for a manual for A Samsung SSC security system
The link for ALL of the Samsung security stuff is:
http://www.gviss.com/Default.aspx?tabid=97
Pass it on......
fixemall......
Posted on Jul 21, 2008
  • 5 Answers
SOURCE: No picture
The green connectors are for PIR (passive infrared ) motion sensors to be connected, they have nothing to do with you recieving a signal from your cameras. Double check to make sure the camera jacks are securely connected on both ends (camera & monitor) , and then hit your AUTO button which should automatically cycle through your cameras if you are indeed getting a signal. If you arent, you have other issues. As to the monitor getting darker. You will need to adjust the brightness from day to night unless you have an alternate light source or IR(infrared) Illuminator for night viewing.
Posted on Aug 09, 2008
Complete service manual for Samsung B/W Observation Monitor SSC-12M AC120V, 60 Hz, 38 W. The green front panel power lamp flashes and the machine emits a clicking sound. I have checked connectivity to...
Unfortunately, the devices aren't listed as the "set" - can you reply with the exact model number from the main unit?
If i cannot obtain the schematics after hearing from you... I will contact Customer Service to initiate a refund or switch to another expert.
Thanks!
Sep 28, 2011 | Samsung Weather Resistant Security Camera...
Need Samsung SSC Dual Manual
Hello, I have the PDF version for Samsung SSC-14. I can e-mail it to you. You may contact me via e-mail Anoint2020@aol.com and I will e-mail it to you. Thanks.
JimmyC
Mar 31, 2009 | Home Security
Need a samsung ssc 1280 owners manual
I have PDF manuals for the Samsung SSC-1280, and SSC-14M. Feel free to e-mail me at Anoint2020@aol.com and I will send them to you. Hope this helps.
Mar 12, 2009 | Samsung SSC-960 VHS VCR
Looking to buy a moniter
I have two monitors.
I don't use them, because I used and adapted the cameras in another cctv system.
You can see a picture of them here
http://www.palleyd.com/ssc-12m-monitor.html
Jan 19, 2009 | Samsung Weather Resistant Security Camera...
Samsung ssc-960
can someone send me an an owner manual for ssc-960 time lapse recorder. fcassis58@gmail.com
Aug 31, 2008 | Samsung SSC-960 VHS VCR
I have a Samsung B/W Monitor, model Name SSC-12M for an observation System. Turns on for a few secomds, and then gets a straight line across and turns monitor on and off, Capasitor maybe? Worth repair ing...
The vertical Ic either has bad connections or is defective. Look for a small flat IC attached to a heat sink with about 11 pins. Try resoldering the pins first. If that fails to resolve it, replace the IC. This IC may be marked LA7837 or something similar. If you are unsure, post the marking here and I'll confirm you have the correct part.
Dan
Aug 28, 2008 | Samsung Televison & Video
I have a furuno fcv 585 echo sounder with a FURUNO CA50/200-12M -c13298 BRONZE THRU HULL HIGH PERFORMANCE TRANSDUCER. The transducer has 4 wires and it looks from the schematic that it attaches via a...
you need an MB1100 matching box has the 10 pin pigtail for your sounder and accepts bare wire input from your ducer
this will also ensure that all power from sonar get to ducer, but it from me if you like 847-746-0100
Jul 09, 2008 | Furuno FCV-582L GPS Receiver
No picture
Feb 20, 2008 | Samsung Weather Resistant Security Camera...
I have the same problem and I found out that a resistor went bad and then a capicator went bad.you must have them check and replcaced
Oct 26, 2007 | Samsung Weather Resistant Security Camera...
Am not familiar with an SSC-960, there are however SVR-960 (4 versions) by Samsung.
Normally Samsung follows similar installation procedures and the differences in their model are advance features and the length of recording time. If this could be of any help, this link is a users’ manual for a 1280 hrs model. It includes installation procedures.
Alternately you can try Google for “svr 960 pdf” but when I tried it most that I can get are German language versions.
Hope this be of some help/idea.  Good luck and kind regards.
Aug 25, 2007 | Samsung Weather Resistant Security Camera...
Samsung Weather Resistant Security Camera SSC-12C Logo
345 people viewed this question
Top Samsung Home Security Experts
Bill
Level 1 Expert
bobby little
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
