If it isnt used then fibre glass it over but on the inside re-inforce it by fibre glassing a piece of 19mm copper pipe over the hole so it extends a least 6 inches either side of the hole depending on the size of the hole you might need two pieces thats all ,then away you go it will stand most onslaughts of the sea except a hurricane but then what will stand up to that .Us poor relations in europe i only have a local made small boat with a cabin and i have repaired it twice like this where it had been caught on rocks not by myself but the previous owner and it went twice on two different occasions in two different places and beleave me i got the brown marks both times where a strongwave made it start leaking and thinking i would lose my boat out at sea with this nice new mercury 4t engine but got back with the bilge pump on ,second time i went over the hull with a fine tooth comb but i have picked this tip up about the copper water pipe as bracing from another boat person and it works as the copper will not corrode
Unplug the washing machine from the wall outlet.
Remove the plastic end caps on the left and right sides of the control panel using your fingers, and then remove the screws under the end caps.
Lift the control panel up and rotate it 180 degrees.
Unplug the wire connector from the top of the cabinet and then use a flat-head screwdriver to release the spring clips on the left and right sides of the cabinet.
Tilt the cabinet toward you, then lift and remove. Set the cabinet aside.
