Question about Hitachi PJTX100 Multimedia Projector
PJ-TX300 switches lamp off after lamp replacement
I just replaced a PJ-TX300 lamp.When switched on after 30 seconds the Power and Lampred light come on does not gives me time to go to the menu.Any help to resolve this will be appreciated.
jclito1@googlemail.com
  • Hitachi Master
  • 5,568 Answers
This shutdown may be caused by a heat sensor.
Check to see if the cooling fan is turning at all; without cooling the projector should shut down to avoid setting off a fire or other damage.
If the fan is not operating, you may be able to access it to clean with a small brush.
These fans are also prone to failure since they nearly all have sleeve bearings and develop severe wobble or the shaft may just stick.
Posted on Apr 28, 2008
PJ-TX300 suddenly not detecting HDMI input
I think that its a port issue, if all the other ports are working but hdmi is not then one of the pin on the circuit board may have come loose. I have the same issue. Could try to solder it back on or use a glue gun. let me know if this helps?
Sep 21, 2014 | Hitachi PJ-TX300 LCD Projector
Power led and lamp led blink simultaneously on my jvc hd65s998 rear projection tv
You might need to replace your lamp driver, or ballast as some call it. This is what strikes the lamp to make it light.
Mar 20, 2013 | JVC Televison & Video
My Sanyo PLC XE31 wouldn't switch on, bulb replacemetn lamp was lit. Changed bulb and now it switches on, green light shows, fans run, and then after approx 30 seconds the red light flashes and it switches...
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jan 24, 2011 | Sanyo FOR PLC-XE31
Replaced lamp, still does not turn on.
LAMP #BP96-00826A
IF THE TV STAYS ON FOR 30 SECONDS IT MAY BE AN INDICATOR OF A POSSIBLE POSITIONING ISSUE WITH THE LAMP DOOR SWITCH (LITTLE BLUE SWITCH AT LOWER LEFT OF CABINET WHEN LAMP DOOR IS REMOVED.) THIS SWITCH IS SUPPOSE TO BE IN THE DOWN POSITION ONCE THE LAMP DOOR IS SECURED AND HAS CAUSED CONFUSION BEFORE.
HOPE THIS HELPS
Jul 06, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Hitachi pj-tx300
Hi - You can download the manual by clicking the link underlined in blue below:
pj-tx300
See page 53:
You need to reset the lamp & filter timers.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 10, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
PJ-TX100 Projector won´t start up out of Stand-By
Hi Mario
If there is no response on the Projector it normally means that the Mainboard is faulty.
Check if your machine is still under warranty because this quite expensive to replace.
As far as the schematics are concerned - I'm unfortunately not able to help you out with that.
Apr 02, 2008 | Hitachi PJTX100 Multimedia Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Hitachi PJTX100 Multimedia Projector Logo
208 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
