Question about Viking Kitchen Ranges
The 2nd oven burner doesn't always light and the first seems to cycle on and off frequently. When I give a little rap on what I believe the gas solenoid to be (part #PB010084) both burners light right up. Is this a sure sign the solenoid needs replacement?
Probably not. As the ignitors (Viking part no. PB040001) age, their resistance increases to the point where they don't pull enough current to hold the valve open. This is true even though the ignitors are still glowing brightly. According to someone who probably knows, they are considered a "maintenance item" that needs to be replaced "every few years."
About $45 each at The Gene Schick Co. (510)429-8200. Replace both of them (assuming a 30" oven, 3 if wider) at the same time, or you'll be doing this job again in a few days/weeks/months.
Posted on Aug 23, 2009
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
On our 6 burner gas coocktop, the right two burners don't light
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Mar 30, 2010 | Ovens
Oven takes up to 15 minutes to light. glow plug does appear to be bright orange immediately after turning oven on. it is a propane unit.
Hi, glow plug (element) should glow red, maybe you got faulty thermocouple, located ot bottom of oven burner, unit where gas enter oven burner, they could either be gas pilot or electrical element as metering device, give a little tap, could be stuck, could also be your thermostat, check oven thermostat, many ways to check oven thermostat, give thermocouple a little tap located at beginning of oven burner, if it didn't work, call a mechnic to make futher checks. good luck.
Aug 05, 2009 | Magic Chef CGR3725 Gas Kitchen Range
Oven burner seems to have low flame
Check voltage to gas valve in the back of the boiler compartment. It is way in the back on the left hand side, turn on the top burners. If you do not get any volts or only 1 to 5 volts you will need to replace, It is supposed to have 24 volts to operate correctly
Feb 09, 2009 | Jenn-Air JGS8850AD Gas Kitchen Range
Top burners often wont light if oven is already lit
Hello and welcome,
If your range has electronic igniters, then you seem to have one or more bad igniters on top of the range if you have a pilot range then you have a gas restriction or clogged orifice tube.
Even if they make the click noise while trying to light they may not get hot enough to draw the gas on a constant speed!
This will need to be diagnosed hands on at your location.
But this is the fault!
Thank you for using fixya.
Huum
Please remember to leave a solved rating before you leave!
Dec 07, 2008 | GE Kitchen Ranges
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
Dec 07, 2008 | GE JGBP28 Gas Kitchen Range
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
Kitchen Ranges Logo
178 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
paulcarew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
