Question about Mitsubishi WD-52525 52" Rear Projection HDTV
No power 1st The Tv shut off and there was sound but no picture, orderd lamp, still waiting for it to come. But now i have nothing at all, the status light is blinking and when i press the reset button the fan will come on briefly the a click then nothing. no sound no picture no power just a blinking status light
    Scholar:
  • 131 Answers
If the lamp is bad. it will blink.dont worry make sure you put screws back and cover on there are protection switches.If still blinks after bulb replaced and cover on. it is the thermo fuse on or near bulb, Then after that it get complicated
thanks DOCTOR VIDEO
Posted on May 09, 2008
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Flashing red light saying lamp and no picture.
REPLACE LAMP !!!
Buy an Orginal Replacement Lamp.
May 19, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
No Picture but still has sound
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.The lamp you need is 915P049010. you can find it here: http://www.discount-merchant.com/Mitsubishi-915P049010-Lamp-Replacement-p/mitsubishi-915p049010-lamp.htmHave a blessed one!
May 03, 2010 | Mitsubishi WD-57731 57" Projection HDTV
TV was on and had a picture, and then nothing w/flashing power
Your lamp has blown. Time to get a new one.
the hyperlink button doesn't seem to be working, but just copy and paste this link into your browser. It is linked directly to your tv's replacement bulb.
http://www.discount-merchant.com/JVC-LCD-Projection-TV-Lamp-TS-CL110UAA-TS-CL110U-p/jvc-ts-cl110uaa-hd-56fn97.htm
Nov 11, 2009 | JVC HD-56FN97 56" Television
Sound and picture on and off green light blinks
1st try this....unplug tv...hold power button for 10 seconds...wait 2 minutes....plug back in, if this doesn't fix it you probably need to replace the lamp
Jul 13, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
79 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
