Whirlpool washer does not spin
I bought a Whirlpool Supreme 7 cycle 2 speed washing machine. Was told it did not spin and needed a belt. Problem: I cannot find model number ANYWHERE. There are some numbers stamped in different places, but nothing that indicates model number. What should I do (besides get a new washer). :)
  • Anonymous Apr 13, 2009
    whirlpool 7 cycle 2 speed extra large capacity
  • Anonymous Mar 14, 2014
    what size is my washing machine - whirlpool Model number la5320xtn0
    Genius:
  • 1,073 Answers
This machine does not have a belt it has a direct drive coupling, the coupling is in between the motor and the transmission it is what makes the machine spin part number is 285753a aboout 10-12 dollars give or take
Posted on Apr 28, 2008
Whirlpool washer wet after spin cycle
Hello.
1 Measure your drainpipe to make sure it is no taller than 96 inches in height and no shorter than 30 inches; otherwise, it won't pump enough water from the washer, or the water may flow back to the washer.
2 Look at the dial selection to make sure you have selected the proper spin speed for the material you are washing. Choose the highest spin speed for that particular material. If you choose the "no spin" or "low spin" option, your whirlpool washer might not remove all of the water from your clothes.
3 Check if you have chosen the appropriate wash cycle for the type of material you are washing. The whirlpool washing machine drains quite a bit more slowly on the "Delicate" and "Hand Wash" cycles.
4 Check for excessive soap suds accumulating in the washing machine. whirlpool recommends you use only high-efficiency detergent in whirlpool washers. Other detergents can cause excessive soap suds, which could cause the washing machine to operate at a slower spin speed than selected, resulting in sopping wet clothes.
5 Add more clothing items to the washing load. If you wash only one large item, like a coat or blanket, the washer might become unbalanced and react by lowering the spin speed, causing the machine to not drain as it should during the spin cycle.
6 Examine your drain hose for clogs or kinks. Straighten the hose out to allow water to flow through. Eliminate blockage in the drainpipe or utility sink.
Thanks.
Nov 01, 2011 | Washing Machines
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Trying to locate the belt on a Whirlpool washer
Hi:
Your washer does not have a belt. It has a transmission, and they seem not to fail very often. Usually, the problem lies with the timer or some other switch. What exactly happens when your spin cycle comes around? Normally, after the wash cycle, the machine stops, then the spin cycle starts in the opposite rotation. The first thing that happens is the water is pumped out, then as the speed increases, the spinning throws the rest of the water out of your clothes. If your machine does pump down the water, but doesn't spin fast, then you might have a transmission problem, but if it also fails to pump out the water, you could have a timer or switch problem, as some machines won't spin with the lid open, and if the switch is broken, the machine thinks the lid is open.
Feb 15, 2010 | Whirlpool Washing Machines
Washing machine won't spin dry . Its a whirlpool 2 speed 7 cycle heavy duty model
If this is a top load clothes washer, almost all units will not spin if the door is open during the cycle time when it should be spinning. If the door is closed, check if the door safety interlock is broken (on most washers, you will see a pin on the door pressing into a little depression)
If these things check out, you probably have a failed transmission deep inside the clothes washer. Fixing that is non-trivial.
Aug 20, 2009 | Whirlpool Washing Machines
Washer doesn't spin, just makes funny noise.
i would change the coupler between the motor and transmission.... whirlpoolpartssurplus.com
Jun 23, 2009 | Whirlpool Washing Machines
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Mar 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool awm5125/4 washing machine
If the washer seems to complete all of its cycles, but it doesn't spin: 1) Be sure the load of clothes is not lop-sided. If the tub becomes unbalanced, it may spin erratically or not at all. Open the lid after 2 minute gap and reposition the clothes. This automatically resets an off-balance shut-off switch. Close the lid and re-try. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during the spin cycle. If the switch doesn't click when you press and release it, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The belt may be loose, worn, or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson. Pl post back results
Apr 17, 2007 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
548 people viewed this question
Top Washing Machines Experts
