Question about Maytag Neptune MAH5500B Front Load Washer
HOW TO REMOVE THE TOP OF THE MACHINE?
TRIED TO REPLACE THE HOSE BUT MANAGED TO CROSS THREAD IT. NEED TO REPLACE THE WATER INLET VALVE
  • 135 Answers
You have to remove the front first. 4 screws around the door jam and the front will come off. Then 2 screws hold clips which secure the top behind the front panel. Remove the screws and clips and remove the 4 screws on the top holding the soap dispenser in. The top will now lift up.
Posted on Apr 28, 2008
    Genius:
  • 1,073 Answers
Take a putty knife and about 1 to 2 inches inside from the edge of the case insert the putty knife into the lid latch push in and lift up on the top repeat this process for the other side
Water continues to run into the washing machine through the whole wash cycle and even when the machine is off. I have to keep the tape turned off. other than that the washing machine functions normally.
Hi Welcome to FixYa I am Kelly. You have debris inside your water inlet valve. You can try to clean it by doing the following:
- First remove both hoses from the water inlet valve and remove the inlet screens of the water valve.
(Use a knife blade on the outer part of the screens to remove them from the water valve)
- Connect both hoses to the water inlet valve without the inlet screens.
- Connect ONE hose to the wall faucet
- Place ONE hose in a bucket
SELECT WARM WASH and start wash fill
Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your trying to free the debris from the inlet water valve diaphram)
Stop Fill
Reverse Hose connection at the wall.... i.e. hook up other hose and disconnect the one you had connected. Place the hose you disconnected from the wall into the bucket.
START warm fill
Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your STILL trying to free the debris from the inlet water valve diaphrams)
STOP FILL
- Connect hose to wall connection
- WASH the inlet screens under slowly running water until both sides are clean
- Remove hoses from the water inlet valve and install the inlet screens.
- Reconnect hoses and turn on water supply
TEST HOT and COLD fill
Turn off machine.... IF the debris was freed the water flow will stop when the machine is turned off.
If this flushing attempt does not correct your constant water flow the remedy is to replace the water inlet valve on your washer.
I can help with locating parts ON-Line but will need your model number to help you should you require a water valve.
Hopefully you are able to clear the debris by doing the above. (50 - 50 chance of it working)
Thanks for Choosing FixYa,
Kelly
Dec 17, 2010 | Washing Machines
When the machine is off it is filling up with
It sounds like you're probably looking in the right place...it's possible that the inlet water valve is stuck open or simply defective. Turn off the water, turn off the power, remove the hoses and check the inlet valve. The valve could be stuck, have something in it. You may need to remove the inlet valve(s).
Jul 07, 2010 | Whirlpool GHW9250M Front Load Washer
Washer is stuck at 45 minues
Check the inlet screen on the cold water hose. Turn off the cold valve by the inlet hose, disconnect the hose from the back of the machine, and look for a plugged screen inside the hose thread nipple on the back of the machine. Remove screen, clean it out, replace screen, hose, and turn water back on.
May 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The electronic cold water inlet valves at the top of the machine are leaking. My manual does not list the part and i need to replace it. I dont know the correct part name or number
Water Inlet Valve Replacement Procedure
Cold water inlet valve assembly: Part # 5221ER1003A
Hot water inlet valve: Part # 5220FR2006H
  1. Safety first. Unplug the machine.
  2. Close the water supply valve.
  3. Remove the cold water fill hose and drain the residual water into a pan or bucket.
  4. Remove the two screws on the back of the top panel securing it to the cabinet.
  5. Slide the top panel to the back of the machine and lift it off the cabinet.
  6. Disconnect the wiring harness connectors from the valves. Mark the connectors to make sure you reconnect them to the right valve.
  7. Unscrew the valve assembly from the cabinet and pull it out.
  8. Loosen the hose clamps and remove the hoses from valve assembly.
  9. Connect the hoses to the new valve assembly. Reinstall the valve assembly and the top panel in reverse of the steps above.
  10. Reconnect the fill hose and open the water supply valve.
Jan 26, 2010 | LG WM-2277HW Front Load Washer
How do you replace the mixing valve on a kenmore series 80
Water Inlet (Mixing) Valve Replacement Procedure
  2. Shut off the water supply valve.
  3. Place a bucket or pan under the water inlet valve to catch residual water from the fill hoses.
  4. Remove the fill hoses from the water inlet valve then drain the residual water into the bucket or pan.
  5. Remove the screws holding the console at the back of the machine. On some models, the screws are hidden under the console's removable end caps. To remove, pull the top of the end caps to the front of the machine. On some models, the console is secured to the machine by clips under the front corners of the console. Use a putty knife and insert it's blade under the front corners of the console then push it until the clips are released.
  6. Lift the console then flip it towards the back of the machine.
  7. Disconnect the lid switch wiring harness connector from the body of the machine.
  8. Lift the lid, grab the front rim of the cabinet, not the tub, then rock the cabinet to the front of the machine and pull it all the way.
  9. Remove the screws holding the water inlet valve to the back of the machine.
  10. Move the clamp holding the inlet hose to the water inlet valve to remove it.
  11. Install the new water inlet valve and reassemble the cabinet and the console in reverse of the disassembly steps given above.
Feel free to ask for further assistance if necessary.
Jan 23, 2010 | Kenmore 24032\24036 Top Load Washer
Water pooling in washer in between loads
The problem is caused by a leaking water inlet valve and the only way to solve it is by replacing the water inlet valve assembly. It is an easy "do-it-yourself" fix that only requires a minimum effort.
  1. Remove the three screws at the back of the machine holding the top cover.
  2. Slide the top cover to the back and lift it from the washer.
  3. Put a bucket or pan under the inlet valves.
  4. Remove the fill hoses from the machine and drain the water into the bucket or pan to avoid flooding your floor.
  5. Remove the screws holding the water inlet valve assembly to the back of the machine.
  6. Use a pair of pliers to press the spring clamp holding the inlet hose to the inlet valve assembly and move the spring clamp away.
  7. Install the new water inlet valve assembly and all other parts disassembled in reverse order of the procedure above.
  8. Make sure to clean the fill hose filters, if there's any, before attaching it to the water inlet valve assembly.
Jan 20, 2010 | Kenmore Elite 45986 Front Load Washer
How to replace the water inlet in electrolux kelvinator 760 FXZ washy talky washing machine
TURN ELECTRIC OFF .....top lid off x2 screws on lid....remove water inlet pipe...TURN WATER OFF FIRST :)....undo or unclip on valve...unclamp water clamp on hose ... take off hose ...reomove valve..refit new part ..refit hoses .... test .
Jan 04, 2010 | Washing Machines
Kenmore he3 series washer keeps filling with water when not in use
Remove the 3 screws at the back of the machine that hold the top on. pull back on the top and lift the top off. Remove the hose from the inlet valve and remove the screw that holds the inlet valve.
Aug 12, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Jun 22, 2007 | Creda W100FW Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
102 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
