Question about Refrigerators
My Whirlpool ARC7472 fridge freezer has stopped cooling both feezer and fridge. Removal of the cover in the freezer shows no ice build up, the fan runs, but no cooling effect in the chiller pipework to the evaporator. There appears to be liquid running through the piping as you can hear it 'gurgling'in the freezer - the compressor seems to be running hard and hot. Is this the thermostat faulty, or lack of refridgerant? How do I check for refridgerant loss? Thanks for any help you can give.
    Genius:
  • 1,073 Answers
It is low on refrigerant and has a sealed system leak without the proper leak detection equiptment and charging tools best left to the local ref tech
Posted on Apr 28, 2008
MY FRIDGE ISNT GETTING COLD
Whilpool uses a fan at the back of the freezer to circulate air. If it burns out, the fridge will still cool, but not as well.
However, these don't usually burn out. What usually happens is that ice builds up and prevents air from circulating. If that is the case then you probably need a new bimetal temperature sensor on your cooling coils. This sensor sits at the back of the freezer (behind the wall) and tells the fridge when to defrost. If it doesn't then the ice will plug up the vents and may even stop the fan from working. Hope this helps.
Apr 15, 2014 | Whirlpool Refrigerators
I had ge refrigerator and the fridge is not cooling well
For starters a year and model number would be helpful. Do you have turn dials to contol temp of freezer and fridge or electonic pushbuttons? The fridges with manual rotating dials use a "dampner" between the freezer and fridge section. In short the freezer evap fan blows air in the freezer but also has a passage from the freezer to the fridge section which aloows a controled amount of air from the feezer section to cool the fridge section. IThis passage may be obstructed by ice build up or some other blockage. Units prior to 2002 are not controled by circuit boards and the ones after 2002 are. For more specific help give me the GE fridge model please.
Sep 24, 2012 | GE Refrigerators
Double door fridge stops cooling, autodefrost not working
It wud need a new defrost heater, the fridge gets its air from the freezer , if the defrost heater does not work , ice builds up in the airduct , equals to no cooling in fridge
Feb 01, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My ge fridge model # gss20iemcc is only keeping crisper area cool
If you changed the defroster. you know how to take the top apart. Take the fan cover off there is a lover on the cover should be factory set but sometimes they come loose and stop the air from going to the bottom. while you there look to see if it has ice in it. If it dose. the drain may be stopped up.
Ken
Sep 23, 2009 | GE Refrigerators
Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Hidden Ice build-up inside plastic bottom cover of freezer
Generally, icing is the result of too much water vapor inside the unit, blockage of the circulation channels and too much packing in of the box.  The water vapor is generally caused by: uncapped items in the fridge, opening the door too often, humid conditions, bad door seals.  There is of course, there is a possibility that the defrost cycle on the unit is not working.  About once a day, depending on the brand, you should notice that the fans and compressor don't run and you should hear a bit of creaking, sloshing or other strange noises as the ice melts.  If this is not happening, your defrost timer or the coil it heats could be bad.
Nov 12, 2008 | Refrigerators
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
182 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
